GCC 4.1.1 m68k-rtems generating invalid code for -m5307 processor ?
Ian Caddy
ianc at goanna.iinet.net.au
Mon Jun 25 22:41:02 UTC 2007
Hi Chris,
Chris Johns wrote:
> Ian Caddy wrote:
>> Hi Kevin,
>> We also use the 5307 for our system, and are currently using gcc 4.1.1
>> and we don't see your problem.
<snip>
>> You indicated that you built your tools. Have you tried the standard
>> toolsets from the RTEMS website?
> The rpms on the RTEMS build machine show:
> [chrisjohns at england build]$ ls /opt/rtems-4.7/m68k-rtems4.7/lib/
> crt0.o ldscripts libc.a libg.a libm.a m5200 m68000 m68030 m68040
> m68060 mcpu32 msoft-float
> [chrisjohns at england build]$ ls /opt/rtems-4.8/m68k-rtems4.8/lib/
> No V3 specific builds in the released tool sets.
Oops, bit slow off the mark as I just got back from overseas. We also
roll our own tools for use under msys, and it was a while ago and forgot
that the standard toolchain is not built with m5307 support!
I agree that it looks like a 68020 instruction, so we need to check the
build commands.
Kevin, you indicated in your first email that you created a new BSP.
Would you mind sharing your config file from the rtems-4.7/make/custom
directory so we can check your build options?
regards,
Ian Caddy
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9221 1860
