GCC 4.1.1 m68k-rtems generating invalid code for -m5307 proce ssor ?
Kirspel, Kevin
kevin.kirspel at optimedical.com
Tue Jun 26 12:17:49 UTC 2007
Here is the config file.
# Config file for the mcf5235 BSP
# $Id: mcf5329.cfg,v 2007/01/09 kirspelk Exp $
include $(RTEMS_ROOT)/make/custom/default.cfg
RTEMS_CPU=m68k
RTEMS_CPU_MODEL=mcf5329
# This is the actual bsp directory used during the build process.
RTEMS_BSP_FAMILY=mcf5329EVB
# This is the actual m68k processor for this BSP.
# When gcc-4.3 is released the toolchain will support the mcf5329 processor
#CPU_M68K_PROCESSOR = -mcpu=5329
# until then we will use the 5307.
CPU_M68K_PROCESSOR = -m5307
# This contains the compiler options necessary to select the CPU model
# and (hopefully) optimize for it.
CPU_CFLAGS = $(CPU_M68K_PROCESSOR)
# optimize flag: typically -O2
#CFLAGS_OPTIMIZE_V= -O4 -fomit-frame-pointer
CFLAGS_OPTIMIZE_V= -O0 -ggdb3 -fomit-frame-pointer
# The following are definitions of make-exe which will work using ld as
# is currently required. It is expected that as of gcc 2.8, the end user
# will be able to override parts of the compilers specs and link using gcc.
define make-exe
$(LINK.c) $(AM_CFLAGS) $(AM_LDFLAGS) \
-o $(basename $@).nxe $(LINK_OBJS) $(LINK_LIBS)
$(OBJCOPY) -O binary --strip-all $(basename $@).nxe $@
$(SIZE) $(basename $@).nxe
endef
define make-cxx-exe
$(LINK.cc) $(AM_CFLAGS) $(AM_LDFLAGS) \
endef
# Miscellaneous additions go here
-----Original Message-----
From: Ian Caddy [mailto:ianc at goanna.iinet.net.au]
Sent: Monday, June 25, 2007 6:41 PM
To: Chris Johns
Cc: Kirspel, Kevin; 'rtems-users at rtems.org'
Subject: Re: GCC 4.1.1 m68k-rtems generating invalid code for -m5307
processor ?
Hi Chris,
Chris Johns wrote:
> Ian Caddy wrote:
>> Hi Kevin,
>> We also use the 5307 for our system, and are currently using gcc 4.1.1
>> and we don't see your problem.
<snip>
>> You indicated that you built your tools. Have you tried the standard
>> toolsets from the RTEMS website?
> The rpms on the RTEMS build machine show:
> [chrisjohns at england build]$ ls /opt/rtems-4.7/m68k-rtems4.7/lib/
> crt0.o ldscripts libc.a libg.a libm.a m5200 m68000 m68030 m68040
> m68060 mcpu32 msoft-float
> [chrisjohns at england build]$ ls /opt/rtems-4.8/m68k-rtems4.8/lib/
> No V3 specific builds in the released tool sets.
Oops, bit slow off the mark as I just got back from overseas. We also
roll our own tools for use under msys, and it was a while ago and forgot
that the standard toolchain is not built with m5307 support!
I agree that it looks like a 68020 instruction, so we need to check the
build commands.
Kevin, you indicated in your first email that you created a new BSP.
Would you mind sharing your config file from the rtems-4.7/make/custom
directory so we can check your build options?
regards,
Ian Caddy
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9221 1860
