GCC 4.1.1 m68k-rtems generating invalid code for -m5307 proce ssor ?
Kirspel, Kevin
kevin.kirspel at optimedical.com
Tue Jun 26 12:26:10 UTC 2007
I am using the RTEMS toolchains. CodeSourcery was responsible for adding
new coldfire processors to the gcc-4.3 build which should be coming out this
year. I posted the same question on there message board to see what they
thought.
The issue is that when I compile the rtems toolchains for m68k, they do not
generate the libraries for the m5307 processor. I am currently trying to see
how I can get these libraries generated.
-----Original Message-----
From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
Sent: Tuesday, June 26, 2007 1:21 AM
To: Kirspel, Kevin
Cc: 'Chris Johns'; Ian Caddy; 'rtems-users at rtems.org'
Subject: RE: GCC 4.1.1 m68k-rtems generating invalid code for -m5307 proce
ssor ?
On Mon, 2007-06-25 at 13:50 -0400, Kirspel, Kevin wrote:
> Here is a response from the CodeSourcery guys about this issue.
Are you saying you are using CodeSourcery sources?
The RTEMS toolchain sources are the FSF versions.
Ralf
