Adding device drivers to RTEMS
Chris Johns
chrisj at rtems.org
Fri Jun 29 04:35:38 UTC 2007
hwulf at et-inf.fho-emden.de wrote:
> Thank you very much!
> By the way, is there a support for virtual memory in RTEMS?
No not like you get with Unix or Windows. MMU type hardware is used on some
processors to handle specific mixes of cached and non-cached address spaces.
You need to refer to the specific BSP for details.
Virtual memory is not deterministic.
> Kind regards,
> Hank
> Quoting Chris Johns <chrisj at rtems.org>:
>>> I try to understand the RTEMS IO manager interface.
>>> Am I right that the rtems_device_major_number is the
>>> index of the rtems_driver_address_table Device_drivers[]
>>> to the appropriate driver functions?
>> Yes. See cpukit/sapi/src/io.c:_IO_Initialize_all_drivers and
>> cpukit/sapi/src/ioinitialize.c.
>>> So if I have the following Device_drivers[] array,
>>> I could assume '1' for the major number of the
>>> sound driver?
>> Yes.
>>> rtems_driver_address_table Device_drivers[] = {
>>> CONSOLE_DRIVER_TABLE_ENTRY,
>>> SOUND_DRIVER_TABLE_ENTRY,
>>> { NULL, NULL, NULL, NULL, NULL, NULL }
>>> Kind regards,
>>> Hank
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
