i386-rtems 4.6.6 build problems
D. Peter Siddons siddons at bnl.gov
Thu Mar 1 03:45:19 UTC 2007
Well, I don't think you can do that. The host gcc assumes you are
generating an application to run under the host operating system. You
are not doing that. You are compiling a new operating system which will
run stand-alone. This needs a different compiler, the one which you get
from the rtems site.
Pete.
Ze Manel wrote:
> I'm trying to build rtems for i386, and I come to all sorts of errors
> I've got the required tools with the right versions.
> since I'm compiling it for this arch I am using the gcc that came with
> this operating system (gnu/linux), I just created a symbolic link to it
> with name i386-rtems-gcc so it wouldn't complaint.
> I downloaded version 4.6.6 sources and uncompressed it
> then I made a build dir, went there anda ran "../rtems-4.6.6/configure
> --target=i386-rtems     --disable-posix --disable-networking
> --disable-cxx --prefix=`echo ~`/RTEMS/install_dir/"
> and the make, in the build directory...
> first it kept saying that "no comand didn't exist" and it didn't I
> checked the makefiles and it looked like "ar" was what was intended so I
> changed no to ar. then there was a problem in
> "/cpukit/libcsupport/src/__getpid.c" it aparently lacked an header
> "sys/types.h".
> Now I get another error:
> optimize/open.o -c
> ../../../../../../rtems-4.6.6/c/src/../../cpukit/libcsupport/src/open.c
> ../../../../../../rtems-4.6.6/c/src/../../cpukit/libcsupport/src/open.c:
> In function `open':
> ../../../../../../rtems-4.6.6/c/src/../../cpukit/libcsupport/src/open.c:83:
> error: `_FREAD' undeclared (first use in this function)
> error: (Each undeclared identifier is reported only once
> error: for each function it appears in.)
> ../../../../../../rtems-4.6.6/c/src/../../cpukit/libcsupport/src/open.c:85:
> error: `_FWRITE' undeclared (first use in this function)
> aparently it also lacks an header, only unlike the previous I have no
> idea what it is... Is this normal? I'm compiling the source I got
> directly from rtems server... shouldn't it compile normaly? Can anyone
> spot some kind of error on my procedure?
> thanks.
> rtems-users mailing list
> rtems-users at rtems.com
D. Peter Siddons
Detector Development Group leader,
National Synchrotron Light Source
Brookhaven National Laboratory
Upton, NY 11973
email: siddons at bnl.gov
Phone: (631) 344-2738
