arm-rtems-gcc.exe missing
Karevaara, Teemu
Teemu.Karevaara at PERKINELMER.COM
Thu Mar 8 10:14:22 UTC 2007
An addition:
When I tried to compile the RTEMS sources it gave:
Checking for arm-rtems-gcc... no
Configure: error: no acceptable cc found in $PATH
Do you think this is related to my problem?
-Teemu
> Hello RTEMS-users,
> I have been trying to compile the RTEMS source but I have ran into
> problems.
> I have been following the installation instructions in
> http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.6/share/rtems/h
> tml/started/index.html Can anyone confirm that the manual is
> up-to-date?
> My development environment is WinXP (Pro) and I have installed
> CygWin. The target platform is ARM, more specifically AT91SAM7XC256
> MCU.
> First of all, I downloaded the zipped tar-files which supposed to
> include the prebuilt toolset executables (chapter 3.2 in the
> instructions) As the specs lists following packages:
> rtems-4.6-rtems-base-binutils-2.13.2.1-2.tar.bz2
> rtems-4.6-sparc-rtems-binutils-2.13.2.1-2.tar.bz2
> rtems-4.6-rtems-base-gcc-gcc3.2.3newlib1.11.0-3.tar.bz2
> rtems-4.6-sparc-rtems-gcc-gcc3.2.3newlib1.11.0-3.tar.bz2
> rtems-4.6-rtems-base-gdb-5.2-1.tar.bz2
> rtems-4.6-sparc-rtems-gdb-5.2-1.tar.bz2
> I downloaded the packages:
> rtems-4.6-arm-rtems-binutils-2.13.2.1-2.tar.bz2
> rtems-4.6-arm-rtems-gcc-gcc3.2.3newlib1.11.0-3.tar.bz2
> rtems-4.6-arm-rtems-gdb-5.2-1.tar.bz2
> After unpacking I noticed that the executable arm-rtems-gcc.exe was
> missing (among some other files) The sparc-related packages did
> include the file.
> Thus I cannot proceed as stated in 5.4.
> I was not able to build the executable from the source either. Does
> anyone know is the prebuilt exe available somewhere or is building
> from the source the only option?
> Regards,
> -Teemu Karevaara
URL: <http://lists.rtems.org/pipermail/users/attachments/20070308/11da94dc/attachment.html>
