Problem with messages
Eric Norum norume at aps.anl.gov
Tue Mar 20 11:59:45 UTC 2007
On Mar 20, 2007, at 5:24 AM, Leon Pollak wrote:
> But the buflen parameter is set to 40.
The problem is that you created one message queue capable of holding
40 messages of 1 byte each and another message queue capable of
holding 1 message of 1 byte.  Here's the prototype for
rtems_message_queue_create:
rtems_status_code rtems_message_queue_create(
   rtems_name       name,
   uint32_t         count,
   uint32_t         max_message_size,
   rtems_attribute  attribute_set,
   Objects_Id      *id
> On Tuesday 20 March 2007, you wrote:
>> Hi Mr. Pollak,
>> thank you very much for your quick response.
>> When I change the message buffer length parameter at queue creation
>> to 4 or 8 bytes width, unfortunately it doesn't change anything.
>> Kind regards,
>> Hank
>> Quoting Leon Pollak <leonp at plris.com>:
>>> IMHO, you have defined message length parameter (in queue creation)
>>> as 1 byte,
>>> but try to send a pointer, which is 4 bytes length.
>>> On Tuesday 20 March 2007, hwulf at et-inf.fho-emden.de wrote:
>>>> Hi,
>>>> I'm rather new to RTEMS and I wanted to try out the message queues.
>>>> I'm checking the status codes with a hand-written
>>>> print_status_code()
>>>> function. Creating of the message queues is successful, but when
>>>> trying to send a message from user_task_1 to user_task_2, RTEMS
>>>> says "RTEMS_INVALID_SIZE".
>>>> Does anybody have an idea?
>>>> The example code is shown below.
>>>> Thank you very much and kind regards,
>>>> Hank
>>>>   * INIT
>>>> *** */ rtems_task Init(rtems_task_argument argument)
>>>> 	rtems_status_code status;
>>>> 	puts("\n\n*** TASK COMMUNICATION TEST ***");
>>>> 	 * Building necessary names
>>>> 	Task_name[1] = rtems_build_name('T', 'S', 'K', '1');
>>>> 	Task_name[2] = rtems_build_name('T', 'S', 'K', '2');
>>>> 	Queue_name[1] = rtems_build_name('Q', 'U', 'E', '1');
>>>> 	Queue_name[2] = rtems_build_name('Q', 'U', 'E', '2');
>>>> //	Semaphore_name[1] = rtems_build_name('S', 'E', 'M', '1');
>>>> //	Semaphore_name[2] = rtems_build_name('S', 'E', 'M', '2');
>>>> 	 * Create the user tasks
>>>> 	status = rtems_task_create(Task_name[1], 1,
>>>> RTEMS_MINIMUM_STACK_SIZE *
>>>> 2, RTEMS_DEFAULT_MODES | RTEMS_PREEMPT | RTEMS_TIMESLICE,
>>>> RTEMS_DEFAULT_ATTRIBUTES, &Task_id[ 1 ]);
>>>>    	print_status_code(status, "Creating Task 1");
>>>> 	status = rtems_task_create(Task_name[2], 1,
>>>> RTEMS_DEFAULT_ATTRIBUTES, &Task_id[ 2 ]);
>>>>    	print_status_code(status, "Creating Task 2");
>>>> 	 * Create the message queues
>>>> 	status = rtems_message_queue_create(Queue_name[1], 40, 1,
>>>> 							RTEMS_LOCAL, &Queue_id[1]);
>>>> 	print_status_code(status, "Creating Message Queue 1");
>>>> 	status = rtems_message_queue_create(Queue_name[2], 1, 1,
>>>> 							RTEMS_FIFO | RTEMS_LOCAL, &Queue_id[2]);
>>>> 	print_status_code(status, "Creating Message Queue 2");
>>>> 	 * Create the semaphores
>>>> //	status = rtems_semaphore_create(Semaphore_name[1], 1,
>>>> //							RTEMS_FIFO | RTEMS_BINARY_SEMAPHORE |
>>>> //							RTEMS_NO_INHERIT_PRIORITY | RTEMS_NO_PRIORITY_CEILING |
>>>> //							RTEMS_LOCAL, 2, &Semaphore_id[1]);
>>>> //	print_status_code(status, "Creating Semaphore 1");
>>>> //	status = rtems_semaphore_create(Semaphore_name[2], 1,
>>>> //							RTEMS_LOCAL, 2, &Semaphore_id[2]);
>>>> //	print_status_code(status, "Creating Semaphore 2");
>>>> 	status = rtems_task_start( Task_id[ 1 ], user_task_1, 0 );
>>>> //	rtems_task_wake_after( 100 );
>>>> 	status = rtems_task_start( Task_id[ 2 ], user_task_2, 0 );
>>>> //	rtems_task_wake_after( 5000 );
>>>> 	status = rtems_task_delete( RTEMS_SELF );
>>>> #include <stdio.h>
>>>>   * USER_TASK1
>>>> *** */ rtems_task user_task_1(rtems_task_argument unused)
>>>> //	rtems_id          tid;
>>>> //	rtems_unsigned32  task_index;
>>>> //	rtems_event_set task1_event;
>>>> 	char buffer[40] = "Hello World!\n";
>>>> 	rtems_unsigned32 buflen = 40;
>>>> 	status = rtems_message_queue_send(Queue_id[1], (void*)buffer,
>>>> buflen);
>>>> 	print_status_code(status, "Message sent.");
>>>> 	printf("Task 1: This message was sent to Task 2: %s\n", buffer);
>>>> 	//rtems_message_queue_receive(Queue_id[1], (void*)&buffer,
>>>> &buflen,
>>>> RTEMS_WAIT, RTEMS_NO_TIMEOUT);
>>>> 	rtems_task_wake_after(100);
>>>>   * USER_TASK2
>>>> *** */ rtems_task user_task_2(rtems_task_argument unused)
>>>> 	rtems_id          tid;
>>>> 	rtems_event_set task2_event = 100;
>>>> 	char buffer[40] = "Hello World back!\n";
>>>> 	//rtems_message_queue_send(Queue_id[1], (void*)&buffer, buflen);
>>>> 	status = rtems_message_queue_receive(Queue_id[1], (void*)&buffer,
>>>> &buflen, RTEMS_NO_WAIT, 10);
>>>> 	print_status_code(status, "Message received.");
>>>> 	//printf("Task 2: This message was received: %s\n", buffer);
>>>> 	//rtems_task_wake_after(1);
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>> Dr.Leon M.Pollak
>>>     Director
>>> PLR Information Systems Ltd.
>>> Tel.:+972-98657670
>>> Fax.:+972-98657621
>>> Mob.:+972-544739246
> Dr.Leon M.Pollak
>     Director
> Tel.:+972-98657670
> Fax.:+972-98657621
> Mob.:+972-544739246
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
