rtems_semaphore_obtain
Eric Norum norume at aps.anl.gov
Tue Mar 20 15:03:15 UTC 2007
On Mar 20, 2007, at 8:34 AM, Chris Xenophontos wrote:
> All, thanks for the suggestions-
> The interrupt is a continuous interrupt source, does not need re-
> enabling.
> It is ack'ed in the ISR upon entry, and the H/W regs are being
> loaded into
> global variables.
> Almost appears to be a point at which, during execution of the
> task, that
> release of a semaphore does not register.  Again, this is once in
> about 4-10
> hours, with interrupt being generated every 3.001 seconds.
> I am going to start with a simple fix first, i.e, using a counting
> semaphore, as L. Pollak indicated -
  Be very careful with this since you're using shared variables to
transfer data between the ISR and the task........the interrupt
handler might overwrite the data before the task can get at all or
part of it.  The message queue approach avoids this problem.
I am concerned that you may have uncovered a more serious problem.
I don't have time to go through the semaphore code with a fine
toothed comb and check that there are no possible race conditions --
maybe Joel can do this when he gets back from Europe.  Or perhaps
Daron can do this for us???
> Then we'll look into other more involved solutions
> thanks
> Chris Xenophontos
> -----Original Message-----
> From: Eric Norum [mailto:norume at aps.anl.gov]
> Sent: Monday, March 19, 2007 12:45 PM
> To: Chris Xenophontos
> Cc: rtems-users at rtems.org; 'Tom Phillips'
> Subject: Re: rtems_semaphore_obtain
> Does your hardware interrupt continuously or does the awakened task
> have to do something to reenable the hardware?
> Although you don't say it, I presume that you are now using some sort
> of global variable to communicate the three values read from hardware
> from the ISR to the task.
> How about changing the ISR from using a semaphore to using a message
> queue to send the three values to the task?   This is more robust
> since no data are lost should the task not be able to keep up for a
> brief period because of higher priority tasks in the way.
> On Mar 19, 2007, at 11:31 AM, Chris Xenophontos wrote:
>> Correction,
>> example is incorrect, myIsrSemId is passed as an rtems_id, not as a
>> pointer,
>> thanks Eric,
>> cx
>> Sent: Monday, March 19, 2007 11:47 AM
>> If that's really an accurate description of the code I'm amazed that
>> it works at all.
>> rtems_semaphore_obtain and rtems_semaphore_release take an rtems_id
>> as their first argument.  They do not take a pointer to an rtems_id
>> as you have shown.
>> On Mar 19, 2007, at 9:39 AM, Chris Xenophontos wrote:
>>> Hello all,
>>> We have a situation, running RTEMS 4.6.0, on a Coldfire 5208.
>>> One of the threads (tasks) in our application pends with a one-
>>> second
>>> timeout on a semaphore released by an ISR.
>>> The interrupt source that triggers the ISR (for this test case)
>>> runs every 3
>>> seconds (~3.011).  This re-creates the problem more frequently.
>>> Typically, the task will run, timeout once per second, unless the
>>> ISR is
>>> triggered, in which case it will recognize it and process
>>> accordingly.  The
>>> task processes critical values read from hardware that are latched
>>> by the
>>> ISR.  99.99% of the time, it works as expected.
>>> As the ISR trigger "walks" close to the time of task timeout, we
>>> see the
>>> back-to-back executions, as expected.
>>> However, every 10 hours or so, the task will not respond to the
>>> semaphore
>>> released from the ISR, even though debugging clearly shows the ISR
>>> responded
>>> to the HW interrupt and latched the hardware values.
>>> The effect is a dropped interrupt - the rtems_semaphore_obtain call
>>> does not
>>> return with an RTEMS_SUCCESSFUL status -- it returns a TIMEOUT.  No
>>> other
>>> RTEMS error status are returned either (we check for these well).
>>> The task, ISR, and semaphore_create function that we're using are
>>> listed
>>> below.  Any help appreciated!!
>>> Thanks
>>> Chris Xenophontos
>>> ///////////// mytask//////////////////
>>> mytask()
>>>     while( 1 )
>>>     rtems_status = rtems_semaphore_obtain( &myIsrSemId,
>>>                                             RTEMS_WAIT,
>>>                                             100 );  // 100 ticks =
>>> 1 second
>>>     if(( rtems_status != RTEMS_SUCCESSFUL ) &&
>>>        ( rtems_ststaus != RTEMS_TIMEOUT   ))
>>>        // post error status ( we NEVER see an error here )
>>>     if( rtems_status == RTEMS_SUCCESSFUL )
>>>         // do specific processing based on semaphore released by ISR
>>>         ( not always seen, even though the ISR ran)
>>>     else
>>>         // specific processing based on timeout waiting for
>>> semaphore
>>> //////////////// end mytask///////////
>>> the ISR is as follows
>>> ///////////////////myIsr////////////////
>>> myIsr()
>>>     ( code to ack the Colfire interrupt )...
>>>     code to read 3 hardware registers....
>>>     rtems_semaphore_release( &myIsrSemId );
>>> ///////////////myIsr///////////////////
>>> the semaphore is created as follows, and is always created
>>> succesfully:
>>> status = rtems_semaphore_create( "MISR",  0,
>>> ( RTEMS_FIFO | RTEMS_NO_INHERIT_PRIORITY |
>>> RTEMS_SIMPLE_BINARY_SEMAPHORE |
>>> RTEMS_NO_PRIORITY_CEILING | RTEMS_LOCAL ),
>>> RTEMS_NO_PRIORITY, &myIsrSemId )
>>> mytask is created with the following attributes:
>>> RTEMS_PREEMPT | RTEMS_NO_ASR | RTEMS_NO_TIMESLICE |
>>> RTEMS_INTERRUPT_LEVEL(0),
>>> RTEMS_FLOATING_POINT | RTEMS_LOCAL,
>>> thanks,cx
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>> Eric Norum <norume at aps.anl.gov>
>> Advanced Photon Source
>> Argonne National Laboratory
>> (630) 252-4793
> (630) 252-4793
(630) 252-4793
