C compiler cannot create executables
Amalaye Oyake
amalaye.oyake at jpl.nasa.gov
Thu Mar 29 17:40:24 UTC 2007
I was rebuilding RTEMS and I was running into this problem:
checking for C compiler default output file name... configure: error: C
compiler cannot create executables.
I am assuming that configure was using the cross compiler tools that I built
... it seemed to build everything else just fine, but kept getting hung here
~ pc386/configure failed for pc386.
----host information----
My host system is an Ubuntu box
/RTEMS-4.7/build-gcc$ gcc -v
Using built-in specs.
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --enable-
languages=c,c++,java,f95,objc,ada,treelang --prefix=/usr --enable-shared -
-with-system-zlib --libexecdir=/usr/lib --without-included-gettext --
enable-threads=posix --enable-nls --program-suffix=-4.0 --enable-
__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug --enable-java-
awt=gtk-default --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-
1.4.2-gcj-4.0-1.4.2.0/jre --enable-mpfr --disable-werror --enable-
checking=release x86_64-linux-gnu
Thread model: posix
gcc version 4.0.3 (Ubuntu 4.0.3-1ubuntu5)
----config.log summary----
See `config.log' for more details.
config.status: error:
../../../../../../../../../rtems-4.7.0/c/src/lib/libbsp/i386/pc386/tools/con
figure failed for tools
configure: error:
../../../../../../../../rtems-4.7.0/c/src/lib/libbsp/i386/pc386/configure
failed for pc386
configure: error:
../../../../../../../rtems-4.7.0/c/src/lib/libbsp/i386/configure failed for
lib/libbsp/i386
make[2]: *** [pc586] Error 1
make[2]: Leaving directory `/home/aoyake/RTEMS-4.7/build-rtems/i386-rtems/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/aoyake/RTEMS-4.7/build-rtems/i386-rtems/c'
The config-log says:
conftest.c:1: error: CPU you selected does not support x86-64 instruction
set
configure:2854: $? = 1
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME "rtems-c-src-lib-libbsp-i386-pc386-tools"
| #define PACKAGE_TARNAME "rtems-c-src-lib-libbsp-i386-pc386-tools"
| #define PACKAGE_VERSION "4.7.0"
| #define PACKAGE_STRING "rtems-c-src-lib-libbsp-i386-pc386-tools 4.7.0"
| #define PACKAGE_BUGREPORT "http://www.rtems.org/bugzilla"
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:2893: error: C compiler cannot create executables
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20070329/5e279e2c/attachment.txt>
