rtems_semaphore_obtain
Thu Mar 29 20:17:42 UTC 2007
Johan Zandin wrote:
> Sergei Organov  writes:
>> "Johan Zandin" <johan.zandin at space.se> writes:
>>>        _Context_Switch( &executing->Registers, &heir->Registers );
>>>        executing = _Thread_Executing;
>>>        _ISR_Disable( level );         -----+
>>>                                            |  Region where
>>>     }                                      |  an occuring
>>>                                            |  interrupt
>>>      _Thread_Dispatch_disable_level = 0;   |  causes problems
>>>      _ISR_Enable( level );            -----+
>> But how interrupt can occur when it's disabled in this region?! If
>> _ISR_Disable()/_ISR_Enable() don't work on your target, you have hard
>> trouble anyway.
> The HW interrupt occurs but is left pending until ISRs are enabled,
> so the ISR does not execute until somewhere within the _ISR_Enable call
> (in the first cycle when ISRs are enabled in the CPU again).
In the failure case I see, it is executed around the 3rd instruction of
c/src/lib/libcpu/sparc/syscall/syscall.S.  This holds true for your
executable, as well as ones I have built for
  + head of 4.6 branch
  + head of 4.7 branch
  + 4.7 branch with events
I thought there are some assumptions about what doing a syscall
guarantees us and it doesn't look like it is happening in this case.
But that's just my memory. Let's see what Jiri says. :)
--joel
> /Johan
> Johan Zandin                      Software Engineer
> Saab Space AB                     Phone: +46-31-735 41 47
> SE-405 15 Gothenburg, Sweden      Fax:   +46-31-735 40 00
> rtems-users mailing list
> rtems-users at rtems.com
