C compiler cannot create executables
Ralf Corsepius ralf.corsepius at rtems.org
Thu Mar 29 21:03:25 UTC 2007
On Thu, 2007-03-29 at 10:40 -0700, Amalaye Oyake wrote:
> I was rebuilding RTEMS and I was running into this problem:
> checking for C compiler default output file name... configure: error: C
> compiler cannot create executables.
> I am assuming that configure was using the cross compiler tools that I built
> ... it seemed to build everything else just fine, but kept getting hung here
> ~ pc386/configure failed for pc386.
I presume this to be a known issue with the 4.7.0 release and building
i386 targets on non-multilib'ed x86_64 systems.
Can you try with RTEMS CVS from rtems-4-7-branch?
Ralf
