Building GNU Cross Compiler Toolset (v4.7.0)
Ralf Corsepius ralf.corsepius at rtems.org
Mon Mar 12 16:02:23 UTC 2007
On Mon, 2007-03-12 at 10:50 -0500, Joel Sherrill wrote:
> Ralf Corsepius wrote:
> > On Mon, 2007-03-12 at 11:42 +0000, Karevaara, Teemu wrote:
> >> binutils-2.17-rtems4.7-20061021.diff
> >> newlib-1.15.0-rtems4.7-20070110.diff
> >> gcc-4.1.1-rtems4.7-20070101.diff
> >>  Does anyone know where the files are or are they needed at all?
> > The diffs being mention in the docs are those versions which had been
> > current when the docs had been updated and don't necessarily match with
> > those actually being used.
> I built the 4.7.0 documentation last week.  So it shouldn't be horribly
> out of date.
It is, because the version numbers are hard-coded into docs/ and are not
automatically generated.
Also, note: The toolchains and their versions are decoupled from a
particulare RTEMS release. There is no strict and constant binding
between toolchain patches/toolchain version and RTEMS release.
>  If those are not the current diffs, what step do you think I
> missed in
> making the documentation?
Editing the docs (I presume the OP was referring to docs/)
>   I went ahead and cut 4.7.0 primarily to catch
> these type of procedural errors. :)
The only way I can think of to remedy this situation is to put the
patches into a directory and let the docs point to this.
I have no idea where you pushed the toolchain sources to nor do I have
write access to this directory.
Ralf
