Problem with messages
Leon Pollak
leonp at plris.com
Tue Mar 20 10:24:13 UTC 2007
But the buflen parameter is set to 40.
On Tuesday 20 March 2007, you wrote:
> Hi Mr. Pollak,
> thank you very much for your quick response.
> When I change the message buffer length parameter at queue creation
> to 4 or 8 bytes width, unfortunately it doesn't change anything.
> Kind regards,
> Hank
> Quoting Leon Pollak <leonp at plris.com>:
> > IMHO, you have defined message length parameter (in queue creation)
> > as 1 byte,
> > but try to send a pointer, which is 4 bytes length.
> > On Tuesday 20 March 2007, hwulf at et-inf.fho-emden.de wrote:
> >> Hi,
> >> I'm rather new to RTEMS and I wanted to try out the message queues.
> >> I'm checking the status codes with a hand-written print_status_code()
> >> function. Creating of the message queues is successful, but when
> >> trying to send a message from user_task_1 to user_task_2, RTEMS
> >> says "RTEMS_INVALID_SIZE".
> >> Does anybody have an idea?
> >> The example code is shown below.
> >> Thank you very much and kind regards,
> >> Hank
> >> * INIT
> >>*** */ rtems_task Init(rtems_task_argument argument)
> >> rtems_status_code status;
> >> puts("\n\n*** TASK COMMUNICATION TEST ***");
> >> * Building necessary names
> >> Task_name[1] = rtems_build_name('T', 'S', 'K', '1');
> >> Task_name[2] = rtems_build_name('T', 'S', 'K', '2');
> >> Queue_name[1] = rtems_build_name('Q', 'U', 'E', '1');
> >> Queue_name[2] = rtems_build_name('Q', 'U', 'E', '2');
> >> // Semaphore_name[1] = rtems_build_name('S', 'E', 'M', '1');
> >> // Semaphore_name[2] = rtems_build_name('S', 'E', 'M', '2');
> >> * Create the user tasks
> >> status = rtems_task_create(Task_name[1], 1, RTEMS_MINIMUM_STACK_SIZE *
> >> 2, RTEMS_DEFAULT_MODES | RTEMS_PREEMPT | RTEMS_TIMESLICE,
> >> RTEMS_DEFAULT_ATTRIBUTES, &Task_id[ 1 ]);
> >> print_status_code(status, "Creating Task 1");
> >> status = rtems_task_create(Task_name[2], 1, RTEMS_MINIMUM_STACK_SIZE *
> >> RTEMS_DEFAULT_ATTRIBUTES, &Task_id[ 2 ]);
> >> print_status_code(status, "Creating Task 2");
> >> * Create the message queues
> >> status = rtems_message_queue_create(Queue_name[1], 40, 1,
> >> RTEMS_LOCAL, &Queue_id[1]);
> >> print_status_code(status, "Creating Message Queue 1");
> >> status = rtems_message_queue_create(Queue_name[2], 1, 1,
> >> RTEMS_FIFO | RTEMS_LOCAL, &Queue_id[2]);
> >> print_status_code(status, "Creating Message Queue 2");
> >> * Create the semaphores
> >> // status = rtems_semaphore_create(Semaphore_name[1], 1,
> >> // RTEMS_FIFO | RTEMS_BINARY_SEMAPHORE |
> >> // RTEMS_NO_INHERIT_PRIORITY | RTEMS_NO_PRIORITY_CEILING |
> >> // RTEMS_LOCAL, 2, &Semaphore_id[1]);
> >> // print_status_code(status, "Creating Semaphore 1");
> >> // status = rtems_semaphore_create(Semaphore_name[2], 1,
> >> // RTEMS_LOCAL, 2, &Semaphore_id[2]);
> >> // print_status_code(status, "Creating Semaphore 2");
> >> status = rtems_task_start( Task_id[ 1 ], user_task_1, 0 );
> >> // rtems_task_wake_after( 100 );
> >> status = rtems_task_start( Task_id[ 2 ], user_task_2, 0 );
> >> // rtems_task_wake_after( 5000 );
> >> status = rtems_task_delete( RTEMS_SELF );
> >> #include <stdio.h>
> >> * USER_TASK1
> >>*** */ rtems_task user_task_1(rtems_task_argument unused)
> >> // rtems_id tid;
> >> // rtems_unsigned32 task_index;
> >> // rtems_event_set task1_event;
> >> char buffer[40] = "Hello World!\n";
> >> rtems_unsigned32 buflen = 40;
> >> status = rtems_message_queue_send(Queue_id[1], (void*)buffer, buflen);
> >> print_status_code(status, "Message sent.");
> >> printf("Task 1: This message was sent to Task 2: %s\n", buffer);
> >> //rtems_message_queue_receive(Queue_id[1], (void*)&buffer, &buflen,
> >> RTEMS_WAIT, RTEMS_NO_TIMEOUT);
> >> rtems_task_wake_after(100);
> >> * USER_TASK2
> >>*** */ rtems_task user_task_2(rtems_task_argument unused)
> >> rtems_id tid;
> >> rtems_event_set task2_event = 100;
> >> char buffer[40] = "Hello World back!\n";
> >> //rtems_message_queue_send(Queue_id[1], (void*)&buffer, buflen);
> >> status = rtems_message_queue_receive(Queue_id[1], (void*)&buffer,
> >> &buflen, RTEMS_NO_WAIT, 10);
> >> print_status_code(status, "Message received.");
> >> //printf("Task 2: This message was received: %s\n", buffer);
> >> //rtems_task_wake_after(1);
> >> _______________________________________________
> >> rtems-users mailing list
> >> rtems-users at rtems.com
> >> http://rtems.rtems.org/mailman/listinfo/rtems-users
> > Dr.Leon M.Pollak
> > Director
> > PLR Information Systems Ltd.
> > Tel.:+972-98657670
> > Fax.:+972-98657621
> > Mob.:+972-544739246
Dr.Leon M.Pollak
Director
Tel.:+972-98657670
Fax.:+972-98657621
Mob.:+972-544739246
