rtems_semaphore_obtain
Eric Norum norume at aps.anl.gov
Tue Mar 20 20:18:45 UTC 2007
On Mar 20, 2007, at 2:39 PM, Chris Xenophontos wrote:
> The first change I've made is to create a Counting Semaphore, i.e,
> changed
> the attributes of the semaphore in question from:
> ( RTEMS_FIFO |
>   RTEMS_NO_INHERIT_PRIORITY |
>   RTEMS_SIMPLE_BINARY_SEMAPHORE |
>   RTEMS_NO_PRIORITY_CEILING |
>   RTEMS_LOCAL ),
> to:
> ( RTEMS_FIFO |
>   RTEMS_COUNTING_SEMAPHORE  |
>   RTEMS_LOCAL ),
> I have to let it run like this another 18 hours to see if there is any
> change.
> If I understand your comments, Binary Semaphores should not be
> called from
> ISRs?
Sergei -- Are you perhaps confusing Binary Semaphores with Simple
Binary Semaphores?
Simple binary semaphores do not have the "unlock only by locking
thread" restriction -- if they did then Chris's program would never
work at all.
I don't see why it should be illegal to release a simple binary
semaphore from an interrupt handler.
BTW -- I usually use events to unblock tasks waiting for interrupts.
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
