Trouble with "test -x"
    Chris Johns
    chrisj at rtems.org
    Thu Mar 22 09:52:09 UTC 2007
Alex Zolotov wrote:
> There is a following line "$as_test_x conftest$ac_exeext; then...." in
> the "checking for RTEMS newlib" section of cpukit/configure file. But my
> arm-rtems-gcc compiling programs without exec. permission, so "test -x"
> command returns FALSE and i got Rtems without Newlib :(
I have also tripped over this one. This is new in autoconf-2.61.
Is this on Cygwin or MinGW ?
If Cygwin please update the bug I have open on the topic stating so:
   https://www.rtems.org/bugzilla/show_bug.cgi?id=1228
> How can i solve this?
There is no simple solution I have figured out. I have hacked a local
copy of autoconf to fix the problem. If you need a patch I can provide
one but I do not like the patch and it is not a solution. It does
nothing more than revert the change in autoconf referenced in the bug
report.
For me the issue is not clear cut. The $ac_exeext variable is not set to
.exe on Windows for our cross-compilers. Autoconf looks for the default
output file name and uses that to determine the value for $ac_exeext.
The RTEMS tools default to a.out. Should we generate a.exe as the
default on Windows ?
Ralf makes an excellent point in the bug about a cross-compiler needing
to set the execute bit so the test in autoconf is valid.
Regards
