rtems_semaphore_obtain
Thomas Doerfler (nt)
Thomas.Doerfler at imd-systems.de
Thu Mar 29 19:27:42 UTC 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi,
Some while ago we had a thread on the rtems mailing list which might
handle your problem. We found out, that gcc takes the liberty to move
some memory accesses that should occure between the irq disable/enable
calls to a location before or after the irq disabled section. Try
looking for a keyword like "memory barrier" on the mailing list archive :-)
wkr,
Thomas.
Johan Zandin schrieb:
> Sergei Organov writes:
>>"Johan Zandin" <johan.zandin at space.se> writes:
>>> _Context_Switch( &executing->Registers, &heir->Registers );
>>> executing = _Thread_Executing;
>>> _ISR_Disable( level ); -----+
>>> | Region where
>>> } | an occuring
>>> | interrupt
>>> _Thread_Dispatch_disable_level = 0; | causes problems
>>> _ISR_Enable( level ); -----+
>>But how interrupt can occur when it's disabled in this region?! If
>>_ISR_Disable()/_ISR_Enable() don't work on your target, you have hard
>>trouble anyway.
> The HW interrupt occurs but is left pending until ISRs are enabled,
> so the ISR does not execute until somewhere within the _ISR_Enable call
> (in the first cycle when ISRs are enabled in the CPU again).
> /Johan
> Johan Zandin Software Engineer
> Saab Space AB Phone: +46-31-735 41 47
> SE-405 15 Gothenburg, Sweden Fax: +46-31-735 40 00
> rtems-users mailing list
> rtems-users at rtems.com
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at:
http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFGDBMswHyg4bDtfjQRAshFAJ9CCTaeF89pnc0/43dHX8OzUDnM2QCgjmuz
LIoRrwohAlRbJJfF5mPNigk=
=ihwI
-----END PGP SIGNATURE-----
