Can't build: "`CFLAGS' has changed since the previous run"
Ralf Corsepius ralf.corsepius at rtems.org
Mon May 7 07:24:54 UTC 2007
On Fri, 2007-05-04 at 08:12 -0500, Eric Norum wrote:
> The problem you're seeing is because of a disagreement about trailing
> spaces.  Here's a script which I run from the top of the newlib
> source tree before running configure.  The script adds some commands
> to each configure script to strip trailing spaces before comparing
> the values.
> BTW -- are you building on OS X?  That's where I encountered this
> problem.
This issue has nothing to do with OS X nor is running a script the
appropriate fix.
The bug causing this issue is in GCC-4.1.x's toplevel configure script
and its interaction with newlib-1.15.0's configure script.
Ralf
