Replacing VxWorks with RTEMS
Ali Asgar Nasir aliasgar.nasir at patni.com
Tue May 8 11:51:17 UTC 2007
Hi,
We have changed the RTOS in one of our application to RTEMS. It took us
around three months to do the same. We have implemented wrapper functions
around the original OS calls which we had in our legacy OS. This makes the
code changes in the actual application to minimum. We just then link the
wrapper's to the OS calls in the application and remove the legacy OS's
libraries.
U need to be clear about the memory mapping and all hardware related stuff
of your target. It will make the changeover smooth.
Regards
Ali
-----Original Message-----
From: rtems-users-bounces+aliasgar.nasir=patni.com at rtems.org
[mailto:rtems-users-bounces+aliasgar.nasir=patni.com at rtems.org] On Behalf Of
brad chisholm
Sent: Thursday, May 03, 2007 3:56 PM
To: rtems-users at rtems.org
Subject: Replacing VxWorks with RTEMS
Hi there,
I am currently investigating the possibility of replacing VxWorks with
RTEMS in an existing product that has been released to customers.
I am trying to get a feel for the length of time the change will take,
can anyone give practical advice on the length of time it has taken them
to get RTEMS running on a target platform and then to replace an
existing RTOS with RTEMS.
- We use a predominantly posix interface into the RTOS.
- For a guide to system complexity, we run approximately 50 threads
concurrently, use semophores, mutexes and signals. There are hard
real-time deadlines and we use 3rd party stacks.
Thank you for any information
Regards
Brad
rtems-users mailing list
rtems-users at rtems.com
http://rtems.rtems.org/mailman/listinfo/rtems-users
http://www.patni.com
World-Wide Partnerships. World-Class Solutions.
_____________________________________________________________________
This e-mail message may contain proprietary, confidential or legally
privileged information for the sole use of the person or entity to
whom this message was originally addressed. Any review, e-transmission
dissemination or other use of or taking of any action in reliance upon
this information by persons or entities other than the intended
recipient is prohibited. If you have received this e-mail in error
kindly delete  this e-mail from your records. If it appears that this
mail has been forwarded to you without proper authority, please notify
us immediately at netadmin at patni.com and delete this mail.
