Howto cancel a blocked termios read request
Eric Norum norume at aps.anl.gov
Tue May 8 14:55:37 UTC 2007
At the expense of yet more bloat in termios.c perhaps the best thing
would be to add support for an FIOCANCEL ioctl request (like vxWorks
provides):
	    ioctl(fd, FIOCANCEL, NULL);
Might be a addition to the network stack, too.
On May 8, 2007, at 6:19 AM, Joel Sherrill wrote:
> Wolfram Wadepohl wrote:
>> i need to cancel a blocked termios read request.
>> the request blocks at the tty->rawInBuf.Semaphore in
>> fillBufferQueue():
>>      * Wait for characters
>>     if ( wait ) {
>>         sc = rtems_semaphore_obtain (tty->rawInBuf.Semaphore,
>>             tty->rawInBufSemaphoreOptions,
>>             timeout);
>>         if (sc != RTEMS_SUCCESSFUL)
>>             break;
>> using ioctl to set c_cc[VMIN] = c_cc[VTIME] = 0 does not help,
>> because
>> it changes only tty->rawInBufSemaphoreOptions, which will be in
>> effect
>> for the *next* call to rtems_semaphore_obtain().
>> should we put an extra rtems_semaphore_release() call in the code,
>> when we set tty->rawInBufSemaphoreOptions to RTEMS_NO_WAIT (line 571)
>> in case of c_cc[VMIN] = c_cc[VTIME] = 0?
>> any other suggestions to cancel a blocked read?
> Can that semaphore be flushed?  I don't know what the API would be to
> the user but that should
> end up returning not satisfied.
> It would also allow it to be canceled on a signal.
> --joel
>> thanks.
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
