accessing the serial device
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Thu May 10 11:09:59 UTC 2007
Hello Hank,
it is a bit difficult to answer your question, when you do not give any
information about the board/hardware/BSP you want to use.
What kind of FPGA baords are you using/which processor and peripherals
are implemented in the FPGAs? Is it a PPC/virtex/ an Altera/NIOS? A LEONx?
When you have identified your hardware, you might also want to look into
the respective console driver of the BSP you are using.
wkr,
Thomas.
hwulf at et-inf.fho-emden.de schrieb:
> Hi,
> I wanted to use the POSIX interface of RTEMS to build up
> a serial communication with two FPGA boards running RTEMS.
> What is the name of the serial interface device? Is it
> /dev/ttyS0 like it is named on linux?
> Thank you very much and kind regards,
>   Hank
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
