Pc386 bsp problem
Arquer Stephane
stephane.arquer at stage.cnes.fr
Fri May 11 14:09:32 UTC 2007
Hi,
I am trying to work with code generated by matlab RTW. This soft must be able to run under a Leon 3 or a pc386 platform.
I work with Tsim and my code seems to work correcly but when I try to run it on a pc, the task calling the matlab step function crash.
Is there a specific configuration to do ?
This is my init configuration variables:
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
#define CONFIGURE_TEST_NEEDS_TIMER_DRIVER
#define CONFIGURE_INIT_TASK_PRIORITY 110
#define CONFIGURE_MAXIMUM_TASKS 128
#define CONFIGURE_MAXIMUM_SEMAPHORES 20
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 10
#define CONFIGURE_MAXIMUM_TIMERS 16
#define CONFIGURE_MAXIMUM_PERIODS 16
#define CONFIGURE_MICROSECONDS_PER_TICK 50 // 1 tick toute les 50µs
#define CONFIGURE_TICKS_PER_TIMESLICE 200
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#ifdef pc386
#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE rtems_driver_address_table Device_drivers[5] = { CONSOLE_DRIVER_TABLE_ENTRY, TTY1_DRIVER_TABLE_ENTRY,
TTY2_DRIVER_TABLE_ENTRY,
CLOCK_DRIVER_TABLE_ENTRY, {NULL, NULL, NULL, NULL, NULL, NULL} }; #endif //pc386
#define CONFIGURE_EXTRA_TASK_STACKS (3 * RTEMS_MINIMUM_STACK_SIZE)
#define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 10
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
#include <confdefs.h>
Regards.
Stephane.
