Pc386 bsp problem
Arquer Stephane
stephane.arquer at stage.cnes.fr
Mon May 14 09:12:27 UTC 2007
Hi,
Effectively, 50 microseconds was originily set to generate a clock at 32Hz.
But I don't use it for the moment.
I changed this defines to avoid any other problems:
#define CONFIGURE_MICROSECONDS_PER_TICK 1000
#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT + RTEMS_GLOBAL
The tasks are created to use floating point, I think the creation function tdemar is correct.
Attached, you 'll find the code I use.
Thanks.
Stéphane.
> -----Message d'origine-----
> De : Daron Chabot [mailto:daron.chabot at usask.ca]
> Envoyé : vendredi 11 mai 2007 17:49
> À : Arquer Stephane
> Cc : rtems-users at rtems.org
> Objet : Re: Pc386 bsp problem
> Without seeing the code in question, it's difficult to
> diagnose. But, as a general comment, 50 microseconds per tick
> is *extremely* fast: your system will spend a good portion of
> each tick responding to timer interrupts...
> -- dc
> On Fri, 2007-05-11 at 16:09 +0200, Arquer Stephane wrote:
> > Hi,
> > I am trying to work with code generated by matlab RTW. This
> soft must
> > be able to run under a Leon 3 or a pc386 platform. I work with Tsim
> > and my code seems to work correcly but when I try to run it
> on a pc,
> > the task calling the matlab step function crash.
> > Is there a specific configuration to do ?
> > This is my init configuration variables:
> > #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> > #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
> > #define CONFIGURE_TEST_NEEDS_TIMER_DRIVER
> > #define CONFIGURE_INIT_TASK_PRIORITY 110
> > #define CONFIGURE_MAXIMUM_TASKS
> 128
> > #define CONFIGURE_MAXIMUM_SEMAPHORES 20
> > #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 10
> > #define CONFIGURE_MAXIMUM_TIMERS 16
> > #define CONFIGURE_MAXIMUM_PERIODS 16
> 50 // 1 tick toute les 50µs
> > #define CONFIGURE_TICKS_PER_TIMESLICE 200
> > #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > #ifdef pc386
> > #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> rtems_driver_address_table Device_drivers[5] = {
> CONSOLE_DRIVER_TABLE_ENTRY, TTY1_DRIVER_TABLE_ENTRY,
> > TTY2_DRIVER_TABLE_ENTRY,
> > CLOCK_DRIVER_TABLE_ENTRY, {NULL, NULL, NULL, NULL,
> NULL, NULL} }; #endif //pc386
> > #define CONFIGURE_EXTRA_TASK_STACKS (3 *
> RTEMS_MINIMUM_STACK_SIZE)
> > #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 10
> > #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
> > #include <confdefs.h>
> > Regards.
> > Stephane.
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
Desc: init.h
URL: <http://lists.rtems.org/pipermail/users/attachments/20070514/c04de39a/attachment.obj>
Desc: init.c
URL: <http://lists.rtems.org/pipermail/users/attachments/20070514/c04de39a/attachment-0001.obj>
Desc: gestionModeleSimulink.c
URL: <http://lists.rtems.org/pipermail/users/attachments/20070514/c04de39a/attachment-0002.obj>
Desc: gestionModeleSimulink.h
URL: <http://lists.rtems.org/pipermail/users/attachments/20070514/c04de39a/attachment-0003.obj>
