bug in gen5200/tod/pcf8563.c
Ingolf Steinbach ingolf.steinbach at googlemail.com
Mon May 14 21:08:09 UTC 2007
Hi.
2007/5/14, Wolfram Wadepohl <Wolfram.Wadepohl at ek-automation.com>:
> Disasembler code is available but i'm nat capable to interpret PPC assembly
> language:
> Defining From_BCD() as an inline function works perfectly.
I don't know PPC assembly either. But maybe the reason for your
problem becomes obvious if you compare the assembler code resulting
from the macro version with the assembler code resulting from the
inline function version of From_BCD(). Could you post both of them?
Cheers
Ingolf
