gcc bug? (was bug in gen5200/tod/pcf8563.c)
Wolfram Wadepohl
Wolfram.Wadepohl at ek-automation.com
Tue May 15 14:11:47 UTC 2007
Ingolf Steinbach schrieb:
> 2007/5/15, Wolfram Wadepohl <Wolfram.Wadepohl at ek-automation.com>:
>> | v1 = info[PCF8563_DAY_ADR-PCF8563_SECOND_ADR] &
>> PCF8563_DAY_MASK;
>> 175| time->day = From_BCD(v1);
> How exactly is info declared. If it is meant to be a pointer to some
> hardware register, it should be volatile qualified (e.g. "uint32_t
> volatile* info").
uint8_t info[10];
uint32_t v1, v2;
info is filled by a function from the i2c bus
> If it is not qualified, an optimizing compiler might (IMO correctly)
> deduce that it is not necessary to place the value read from
> info[....] in the v1 variable if there is no function call between the
> assignment v1 = .... and the expanded From_BCD() macro. The compiler
> might decide that it is equivalent read the value at info[....] twice
> in the macro expansion thus leading to two different _x values.
Schöne Grüße aus Reutlingen
Wolfram Wadepohl
Forschung & Entwicklung
E&K AUTOMATION
Indumat GmbH & Co. KG
Siemensstraße 3
72766 Reutlingen
Deutschland
Tel. +49 7121 514-289
Fax +49 7121 514-299
eMail Wolfram.Wadepohl at ek-automation.com
W.Wadepohl at ieee.org
WWW http://www.ek-automation.com
http://www.indumat.de
Diese Nachricht ist keine geschäftliche Mitteilung i. S. des EHUG.
Bitte senden Sie mir keine Word- oder PowerPoint- (tm Microsoft) Anhänge.
Senden Sie mir einfachen Text, HTML oder PDF.
Siehe http://www.gnu.org/philosophy/no-word-attachments.de.html
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20070515/cd30a2cb/attachment.bin>
