Pc386 bsp problem
Daron Chabot daron.chabot at usask.ca
Tue May 15 15:35:27 UTC 2007
On Mon, 2007-05-14 at 17:34 +0200, Arquer Stephane wrote:
> The failure is an execption raised bay the "simuLoi" task when it calls the step function.
> The task is canceled by the scheduler, only "trwsr" and "trwsw" are running for a moment then a complete crash occurs.
> When I compile the same code with the leon3 bsp, tsim simulator works fine.
Exactly what information does the exception provide ? (exception number,
etc.)
Can you use a debugger (gdb) to step through "task_gestion_loi( )" and
see precisely where the exception is being raised ?
-- dc
