RES: Problem when running hello_world_c with RTEMS 4.7.1 for SPARC
Fabrício de Novaes Kucinskis fabricio at dea.inpe.br
Fri May 18 12:58:19 UTC 2007
>> Are you using the erc32 or sis BSP to run on gdb's simulator?  The sis
BSP enables extra initialization not required on the real hardware.
I'm using SIS to run it. As far as I know, this is the default target for
the ERC32 BSP, so it should run without problem. I'd like to know if the
call to __bsp_board_init was removed by mistake; if not, why hello_world_c
doesn't run on SIS?
Thanks,
Fabrício.
-----Mensagem original-----
De: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Enviada em: quarta-feira, 16 de maio de 2007 10:26
Para: Fabrício de Novaes Kucinskis
Cc: RTEMS - Mailing List
Assunto: Re: Problem when running hello_world_c with RTEMS 4.7.1 for
SPARC
Fabrício de Novaes Kucinskis wrote:
> Hi all,
> Yesterday, I've downloaded RTEMS 4.7.1, and built it to the ERC32 (SIS)
BSP.
> I've compiled hello_world_c and tried to execute it in GDB ("target sim").
Are you using the erc32 or sis BSP to run on gdb's simulator?  The sis BSP
> To my surprise, there was no output. The executable stops when calling
> rtems_initialize_executive_early.
> When looking the BSP source files and comparing it to the ones in 4.6.4
> version, I noticed that, in ...lib/libbsp/sparc/shared/start.S, there was
no
> call to __bsp_board_init (+/- line 640). I added that call and voilá!
> Everything works well now.
> I don't think this call would be removed without a reason, but the absence
> of it was (I think) my problem. I'd like to confirm if this is the real
> problem (and sure, inform it), or if there's something else that I'm not
> getting here.
> Thanks in advance and best regards,
> Fabrício de Novaes Kucinskis - DEA / INPE
> Grupo de Supervisão de Bordo - SUBORD
> Divisão de Eletrônica Aeroespacial
> Instituto Nacional de Pesquisas Espaciais
> rtems-users mailing list
> rtems-users at rtems.com
