Welcome to the "rtems-users" mailing list
Mon May 21 13:51:23 UTC 2007
Yang Anguo,SNLB CD/FN RDC NC(BJ) wrote:
> I would like to volunteer for testing on RTEMS, but could anyone
> Tell me how to logon to the RTEMS server, the public ip address,
> The root/password?
No.
> I think it is not very covenient to set up the testing environment for
> each tester. So it is better to set-up a public testing environment.
No.
The RTEMS environment is easy to setup on your own RPM based Linux.
There is an APT/YUM repository which includes tools for the 4.6 and
4.7 release branches as well as the CVS head (4.8 tools). The CVS
repository is anonymously readable.
You can install the entire environment without root privileges into
your home directory if you want to. Testing can be done on your
hardware or any of a variety of simulators.
I don't even need root access to the RTEMS machines to test.
--joel
--joel
> Best Regards
> Yang Anguo(Mr.)
> 杨安国
> Office: +86 10  5867 1334
> Mobile: +86 139 1008 5283
> Email:  anguo.yang at nsn.com
> -----Original Message-----
> From: rtems-users-bounces+anguo.yang=nsn.com at rtems.org [mailto:rtems-users-bounces+anguo.yang=nsn.com at rtems.org]
> Sent: 2007年5月21日 16:45
> To: Yang Anguo,SNLB CD/FN RDC NC(BJ)
> Subject: Welcome to the "rtems-users" mailing list
> Welcome to the rtems-users at rtems.com mailing list!
> To post to this list, send your email to:
> General information about the mailing list is at:
>   http://rtems.rtems.org/mailman/listinfo/rtems-users
> If you ever want to unsubscribe or change your options (eg, switch to
> or from digest mode, change your password, etc.), visit your
> subscription page at:
>   http://rtems.rtems.org/mailman/options/rtems-users/anguo.yang%40nsn.com
> You can also make such adjustments via email by sending a message to:
>   rtems-users-request at rtems.com
> with the word `help' in the subject or body (don't include the
> quotes), and you will get back a message with instructions.
> You must know your password to change your options (including changing
> the password, itself) or to unsubscribe.  It is:
>   196731
> Normally, Mailman will remind you of your rtems.com mailing list
> passwords once every month, although you can disable this if you
> prefer.  This reminder will also include instructions on how to
> unsubscribe or change your account options.  There is also a button on
> your options page that will email your current password to you.
> rtems-users mailing list
