gcc compiler bug (sparc, ppc)
Till Straumann
strauman at slac.stanford.edu
Tue May 22 23:44:19 UTC 2007
I found that gcc produces bad code for the
following example:
struct node {
struct node *next, *prev;
void xtract(struct node *x)
struct node *n, *p;
n = x->n;
p = x->p;
n->prev = p;
p->next = n;
powerpc-rtems-gcc -O -fschedule-insns -fno-strict-aliasing
(version 4.1.1) produces:
00000000 <xtract>:
0: 81 63 00 04 lwz r11,4(r3)
4: 81 23 00 00 lwz r9,0(r3)
8: 91 2b 00 00 stw r9,0(r11)
c: 91 69 00 04 stw r11,4(r9)
10: 4e 80 00 20 blr
i.e.,
p = x->p;
n = x->n;
p->next = n;
n->prev = p;
The order of the last two assignments was swapped which
makes a difference in the special case where &p->next and &n->prev
are addressing the same location but n != p.
The bug is apparently triggered by -fschedule-insns; if I turn
on all other optimizations (including -fstrict-aliasing) correct
code is generated.
BTW, sparc-gcc-3.2.3 produces the same error (same gcc options as above)
00000000 <xtract>:
0: d2 02 20 04 ld [ %o0 + 4 ], %o1
4: c2 02 00 00 ld [ %o0 ], %g1
8: c2 22 40 00 st %g1, [ %o1 ]
c: 81 c3 e0 08 retl
10: d2 20 60 04 st %o1, [ %g1 + 4 ]
Admittedly, the case where p->next aliases n->prev is unlikely
but this kind of bug hurts confidence in the tool :-(
-- T.
