Pc386 bsp problem
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Wed May 23 15:25:24 UTC 2007
Stephane,
using "RTEMS_MINIMUM_STACK_SIZE" for a task doing heavy math might be
risky. I would expect that your task calls various subroutines, and will
therefore need much more stack. Try increasing it (take additional
64*1024 for a start), maybe you can use the stack checker later on to
analyze in more detail how much stack your task actually consumes.
Note that this "RTEMS_MINIMUM_STACK_SIZE" may also be too small for
other tasks in your system :-)
wkr,
Thomas.
Arquer Stephane schrieb:
> Hi,
> Most of time I don't have any execption number, the task is cancelled while the other are continuing to work and sometimes there is an exception raised but I can't catch it because the console displays lines in continuous. It is the same with remote gdb, I can't see the problem with gdb in remote mode, there is no message.
> This problem occurs when I use complex simulnk models. I think it is a memory configuration allowed for a task. I use floating point unit and I need to do some calculations.
> The task which call the step function is created as follow:
> mode = RTEMS_PREEMPT + RTEMS_TIMESLICE + RTEMS_INTERRUPT_LEVEL(0);
> attributs = RTEMS_FLOATING_POINT + RTEMS_LOCAL ;
> status = rtems_task_create(nommage("simuLoi"),
> 				current_priority,
> 				RTEMS_MINIMUM_STACK_SIZE,
> 				mode,
> 				attributs,
> 				&id_tLoi);
> And my configuration is :
>   							configuration information
> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_TEST_NEEDS_TIMER_DRIVER
> #define CONFIGURE_INIT_TASK_PRIORITY			110
> #define CONFIGURE_INIT_TASK_ATTRIBUTES			RTEMS_FLOATING_POINT + RTEMS_LOCAL
> #define CONFIGURE_MAXIMUM_TASKS				128
> #define CONFIGURE_MAXIMUM_SEMAPHORES			20
> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES			10
> #define CONFIGURE_MAXIMUM_TIMERS				16
> #define CONFIGURE_MAXIMUM_PERIODS				16
> #define CONFIGURE_MICROSECONDS_PER_TICK			1000		// 1 tick every 1ms
> #define CONFIGURE_TICKS_PER_TIMESLICE			200
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #ifdef pc386
> #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> rtems_driver_address_table Device_drivers[5] = {
>    CONSOLE_DRIVER_TABLE_ENTRY,
>    TTY1_DRIVER_TABLE_ENTRY,
>    TTY2_DRIVER_TABLE_ENTRY,
>    CLOCK_DRIVER_TABLE_ENTRY,
>    {NULL, NULL, NULL, NULL, NULL, NULL}
> #endif	//pc386
> #define CONFIGURE_EXTRA_TASK_STACKS         (3 * RTEMS_MINIMUM_STACK_SIZE)
> #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS			10
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS	10
> #include <confdefs.h>
> Thanks for your help.
> Stephane.
>> -----Message d'origine-----
>> De : Daron Chabot [mailto:daron.chabot at usask.ca]
>> Envoyé : mardi 15 mai 2007 17:35
>> À : Arquer Stephane
>> Cc : rtems-users at rtems.org
>> Objet : Re: RE : Pc386 bsp problem
>> On Mon, 2007-05-14 at 17:34 +0200, Arquer Stephane wrote:
>>> The failure is an execption raised bay the "simuLoi" task when it
>>> calls the step function. The task is canceled by the
>> scheduler, only
>>> "trwsr" and "trwsw" are running for a moment then a complete crash
>>> occurs. When I compile the same code with the leon3 bsp, tsim
>>> simulator works fine.
>> Exactly what information does the exception provide ?
>> (exception number,
>> etc.)
>> Can you use a debugger (gdb) to step through
>> "task_gestion_loi( )" and see precisely where the exception
>> is being raised ?
>> -- dc
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
