Pc386 bsp problem
Arquer Stephane stephane.arquer at stage.cnes.fr
Thu May 24 08:12:40 UTC 2007
Good morning,
I changed the stack configuration to:
#define CONFIGURE_EXTRA_TASK_STACKS (64*1024)
The problem is the same, the task is deleted.
> -----Message d'origine-----
> De : Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Envoyé : mercredi 23 mai 2007 17:22
> À : Arquer Stephane
> Cc : Daron Chabot; rtems-users at rtems.org
> Objet : Re: RE : RE : Pc386 bsp problem
> Arquer Stephane wrote:
> > Hi,
> > Most of time I don't have any execption number, the task is
> cancelled
> > while the other are continuing to work and sometimes there is an
> > exception raised but I can't catch it because the console displays
> > lines in continuous. It is the same with remote gdb, I
> can't see the
> > problem with gdb in remote mode, there is no message.
> > This problem occurs when I use complex simulnk models. I
> think it is a
> > memory configuration allowed for a task. I use floating
> point unit and
> > I need to do some calculations. The task which call the
> step function
> > is created as follow:
> > mode = RTEMS_PREEMPT + RTEMS_TIMESLICE + RTEMS_INTERRUPT_LEVEL(0);
> > attributs = RTEMS_FLOATING_POINT + RTEMS_LOCAL ;
> > status = rtems_task_create(nommage("simuLoi"),
> > 				current_priority,
> > 				RTEMS_MINIMUM_STACK_SIZE,
> > 				mode,
> > 				attributs,
> > 				&id_tLoi);
> You can try making the stack large like 64K and adding that to your
> confdefs.h
> (EXTRA_STACKS).  If this is generated code, it can be very
> abusive on the stack.
> You could also switch the console to COM1 and using a
> terminal program to talk to the target.  That way you would
> have logs of the output.
Can you tell me how to connect the console to com1 ?
I've tried to use :
#define USE_COM1_AS_CONSOLE	1
But it doesn't work.
> > And my configuration is :
> configuration information
> > #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> > #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
> > #define CONFIGURE_TEST_NEEDS_TIMER_DRIVER
> > #define CONFIGURE_INIT_TASK_PRIORITY			110
> > #define CONFIGURE_INIT_TASK_ATTRIBUTES
> > #define CONFIGURE_MAXIMUM_TASKS				128
> > #define CONFIGURE_MAXIMUM_SEMAPHORES			20
> > #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES			10
> > #define CONFIGURE_MAXIMUM_TIMERS				16
> > #define CONFIGURE_MAXIMUM_PERIODS				16
> > #define CONFIGURE_MICROSECONDS_PER_TICK
> 1000		// 1 tick every 1ms
> > #define CONFIGURE_TICKS_PER_TIMESLICE			200
> > #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > #ifdef pc386
> > #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
> > rtems_driver_address_table Device_drivers[5] = {
> >    CONSOLE_DRIVER_TABLE_ENTRY,
> >    TTY1_DRIVER_TABLE_ENTRY,
> >    TTY2_DRIVER_TABLE_ENTRY,
> >    CLOCK_DRIVER_TABLE_ENTRY,
> >    {NULL, NULL, NULL, NULL, NULL, NULL}
> > #endif	//pc386
> > #define CONFIGURE_EXTRA_TASK_STACKS         (3 *
> RTEMS_MINIMUM_STACK_SIZE)
> > #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS			10
> > #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS	10
> > #include <confdefs.h>
> > Thanks for your help.
> > Stephane.
> >> De : Daron Chabot [mailto:daron.chabot at usask.ca]
> >> Envoyé : mardi 15 mai 2007 17:35
> >> À : Arquer Stephane
> >> Cc : rtems-users at rtems.org
> >> Objet : Re: RE : Pc386 bsp problem
> >> On Mon, 2007-05-14 at 17:34 +0200, Arquer Stephane wrote:
> >>> The failure is an execption raised bay the "simuLoi" task when it
> >>> calls the step function. The task is canceled by the
> >> scheduler, only
> >>> "trwsr" and "trwsw" are running for a moment then a complete crash
> >>> occurs. When I compile the same code with the leon3 bsp, tsim
> >>> simulator works fine.
> >> Exactly what information does the exception provide ?
> >> (exception number,
> >> etc.)
> >> Can you use a debugger (gdb) to step through
> >> "task_gestion_loi( )" and see precisely where the exception
> >> is being raised ?
> >> -- dc
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
