mallocfreespace.c
Kate Feng feng1 at bnl.gov
Thu May 24 20:28:33 UTC 2007
Till Straumann wrote:
> Kate Feng wrote:
> > Is it better to return 0 instead of -1 if there is no free space in the
> > heap ?
> AFAIK, a return value of -1 indicates an internal error
> (corrupted heap, illegal region id etc.) whereas 0 indicates that no
> free space is available.
> I'm not sure it's a good idea to mingle these together.
> (-1) can tell you that something's really really messed up...
It's true.  Thus, it might be a good idea to printk(" ") the error message
when REMS is really messed up.
Kate
> IMHO, EPICS should check for that case and alert the user.
> -- T.
> > --- mallocfreespace.c.orig Mon Nov 29 17:45:43 2004
> > +++ mallocfreespace.c Thu May 24 13:57:24 2007
> > @@ -40,5 +40,5 @@
> >    if ( !rtems_region_get_free_information( RTEMS_Malloc_Heap,
> > &heap_info ) ) {
> >      return (size_t) heap_info.Free.largest;
> > -  return (size_t) -1;
> > +  return (size_t) 0;
> > Returning -1 broke the following code in EPICS :
> > return (malloc_free_space() > 100000 + contiguousBlockSize);
> > Perhaps,
> > return ( ((int) malloc_free_space() )> 100000 + contiguousBlockSize);
> > would be fine, but I thought it's better to return 0 if there is no
> > free space in the heap.  What do you think ?
> > Kate
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
