Problem when installing 4.8 using yum.
Tue May 29 13:16:50 UTC 2007
Sergei Organov wrote:
> Hello,
> I'm trying to install RTEMS tools using yum (3.0.3) on FC6.
> # yum -c /etc/yum/yum.rtems.com install rtems-4.8-automake-rtems
> Downloading Packages:
> (1/2): rtems-4.8-autoconf 100% |=========================| 623 kB    00:03
> (2/2): rtems-4.8-automake 100% |=========================| 598 kB    00:03
> warning: rpmts_HdrFromFdno: Header V3 DSA signature: NOKEY, key ID 69ce4a83
> Public key for rtems-4.8-autoconf-2.61-5.noarch.rpm is not installed
> How do I fix this?
By importing the gpg key used to sign the packages.  Most, if not all,
of the packages
should be built with the first key:
rpm --import
ftp://ftp.rtems.org/pub/rtems/linux/gpg-pubkey-69ce4a83-44cc2b30
rpm --import ftp://ftp.rtems.org/pub/rtems/gpg-pubkey-EAC29B6F
This is needed any time you add a new source of RPMs.
> [Disclaimer: I usually use Debian-based systems, so have almost no clue
> on how yum works]
Well most of the time and frustrating when it doesn't. :)
-joel
> -- Sergei.
> rtems-users mailing list
> rtems-users at rtems.com
