Rtems_termios_ioctl problem
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Wed May 2 13:41:13 UTC 2007
Hello,
termios buffer management is quite complicated, therefore it is
difficult for me to tell you whether your code might work or not.
I see two problems:
The line where you create rawnc is inside a block after a subroutine
call. Creating variables in C is only allowed at the beginning of a block.
The next thing is your condition "if ( rawnc < 0 )": Since we use the
buffers as ring buffers, the only condition relevant to detect an empty
buffer is (tail == head). Any other combination may indicate a non-empty
buffer.
What I am not sure about is, if a task is waiting for input, it probably
should be woken up during a flush?
wkr,
Thomas.
Arquer Stephane schrieb:
> Hi,
> As I wrote in my previous email, I'm still trying to modify the file termios.c to add TCFLSH request like following:
> case TCFLSH:
> switch (args->buffer) {
> case TCIFLUSH: /* flush input buffer */
> unsigned int head;
> sc = rtems_semaphore_obtain (tty->rawInBuf.Semaphore,
> RTEMS_WAIT,
> RTEMS_NO_TIMEOUT);
> int rawnc = tty->rawInBuf.Tail - tty->rawInBuf.Head;
> if ( rawnc < 0 )
> /* buffer is not empty*/
> head = tty->rawInBuf.Head;
> tty->rawInBuf.Tail = head;
> tty->rawInBuf.theBuf[head] = '\0';
> sc = rtems_semaphore_release (tty->rawInBuf.Semaphore);
> break;
> I don't know if it is the correct way to flush the buffer. If someone knows how to do it,I'm interested.
> Thanks for your help.
> Stéphane.
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-2
Fax : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
