Rtems_termios_ioctl problem
Joel Sherrill
joel.sherrill at oarcorp.com
Wed May 2 19:52:45 UTC 2007
Thomas Doerfler wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> wow, big mistake, I have outed me to know about the flow control
> stuff... :-)
> After digging around in the code (mainly in fillBufferQueue()), I have
> extracted the following lines, which are used there when the input
> buffer has enough space for further reception (which is definitively the
> case when the buffer was flushed).
Should this code be moved to a helper subroutine that is invoked from
both places?
> - ---- snip
> tty->flow_ctrl &= ~FL_IREQXOF;
> /* if tx stopped and XON should be sent... */
> if (((tty->flow_ctrl & (FL_MDXON | FL_ISNTXOF))
> == (FL_MDXON | FL_ISNTXOF))
> && ((tty->rawOutBufState == rob_idle)
> || (tty->flow_ctrl & FL_OSTOP))) {
> /* XON should be sent now... */
> (*tty->device.write)(tty->minor,
> (void *)&(tty->termios.c_cc[VSTART]),
> 1);
> else if (tty->flow_ctrl & FL_MDRTS) {
> tty->flow_ctrl &= ~FL_IRTSOFF;
> /* activate RTS line */
> if (tty->device.startRemoteTx != NULL) {
> tty->device.startRemoteTx(tty->minor);
> - ---- snip
> Stephane, can you add this after you have flushed to input buffer? I
> checks, whether XON must be sent (and sends it possibly) and it also
> takes care about the HW flow control.
> wkr,
> Thomas.
> Eric Norum schrieb:
>> Can someone who's familiar with the flow-control details of termios
>> have a look at the interaction with this?
>> Why do you need to send a break? The 'correct' way to do this would
>> involve changes to low level drivers. A workaround, for those
>> applications that really need to drive the serial line to such a
>> state, is to temporarily set the serial line speed to a lower value,
>> then transmit a NUL character, wait the the transmitter is again
>> idle, and restore the line speed. Of course this means that any
>> incoming characters will be mangled during this time.....
>> <Controversial>
>> My feeling is that the termios code is already too complicated and
>> that all the code to support XON/XOFF flow control should be optional
>> or removed.
>> Does anyone really use this antiquated and unreliable means of flow
>> control any more?
>> I'd be happy with leaving flow control up to the hardware (RTS/CTS)
>> and dropping all references to flow control from the generic termios
>> code.
>> /<Controversial>
>> On May 2, 2007, at 10:53 AM, Arquer Stephane wrote:
>>> Hi,
>>> Thanks for your answers, I've modified the file with your advices
>>> case TCFLSH:
>>> switch (args->buffer) {
>>> case TCIFLUSH: /* flush input buffer */
>>> if ( tty->rawInBuf.Tail != tty->rawInBuf.Head ) /* buffer is not
>>> empty*/
>>> rtems_interrupt_disable (level);
>>> tty->rawInBuf.Head = tty->rawInBuf.Tail;
>>> rtems_interrupt_enable (level);
>>> break;
>>> case TCOFLUSH: /* flush output buffer*/
>>> if ( tty->rawOutBuf.Tail != tty->rawOutBuf.Head )/* buffer is
>>> not empty*/
>>> tty->rawOutBuf.Head = tty->rawOutBuf.Tail;
>>> break;
>>> case TCIOFLUSH: /* flush input & output buffer*/
>>> break;
>>> break;
>>> I call ioctl function with tcflush()
>>> int tcflush (int fd, int queue)
>>> switch (queue){
>>> case TCIFLUSH:
>>> case TCOFLUSH:
>>> case TCIOFLUSH:
>>> return ioctl(fd,TCFLSH,queue);
>>> break;
>>> default: return -1
>>> } //switch
>>> And I am not sure that I'm using the handler ( args->buffer )in the
>>> case TCFLSH correctly
>>> Another problem is for the TCSBRK case.
>>> Can you explain to me how can I send the break signal ?
>>> case TCSBRK:
>>> break;
>>> Thanks for your help.
>>> Stephane
>>>> -----Message d'origine-----
>>>> De : Eric Norum [mailto:norume at aps.anl.gov]
>>>> Envoyé : mercredi 2 mai 2007 16:00
>>>> À : Arquer Stephane
>>>> Cc : rtems-users at rtems.org
>>>> Objet : Re: Rtems_termios_ioctl problem
>>>> 1) Why place the NUL into the buffer?
>>>> 2) The raw input buffer is a ring buffer, so I don't think that your
>>>> rawnc calculation is right.
>>>> 3) The semaphore is being used for process synchronization, not for
>>>> mutual exclusion, so obtaining and releasing it like this is
>>>> incorrect.
>>>> It seems to me that all that's necessary is to:
>>>> This will flush the 'raw' input buffer. Should something happen to
>>>> the 'cooked' buffer as well?
>>> I don't use it for the moment.
>>>> On May 2, 2007, at 7:28 AM, Arquer Stephane wrote. The comment at
>>>> the top of rtems_termios_enqueue_raw_characters
>>>>> Hi,
>>>>> As I wrote in my previous email, I'm still trying to modify the
>>>>> file termios.c to add TCFLSH request like following:
>>>>> case TCFLSH:
>>>>> unsigned int head;
>>>>> sc = rtems_semaphore_obtain
>>>> (tty->rawInBuf.Semaphore,
>>>> RTEMS_WAIT,
>>>> RTEMS_NO_TIMEOUT);
>>>>> int rawnc = tty->rawInBuf.Tail -
>>>> tty->rawInBuf.Head;
>>>>> if ( rawnc < 0 )
>>>>> /* buffer is not empty*/
>>>>> head = tty->rawInBuf.Head;
>>>>> tty->rawInBuf.Tail = head;
>>>>> tty->rawInBuf.theBuf[head] = '\0';
>>>>> sc = rtems_semaphore_release
>>>> (tty->rawInBuf.Semaphore);
>>>>> break;
>>>>> I don't know if it is the correct way to flush the buffer. If
>>>>> someone knows how to do it,I'm interested.
>>>>> Stéphane.
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.com
>>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>>> Eric Norum <norume at aps.anl.gov>
>>>> Advanced Photon Source
>>>> Argonne National Laboratory
>>>> (630) 252-4793
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at:
> http://www.imd-systems.de/pgpkey_en.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.3 (MingW32)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFGOOijwHyg4bDtfjQRAtxzAJ9mNs3s80e7e1TpUL9+8GUJAj37HwCgmNb0
> 4jNfljmrqMmbZ4DasYshJTc=
> =m+5L
> -----END PGP SIGNATURE-----
