Rtems_termios_ioctl problem
Arquer Stephane stephane.arquer at stage.cnes.fr
Thu May 3 08:53:11 UTC 2007
Hi,
If my understanding is correct, in the case of using the flow ctrl mode  XON/XOFF or RTS we need to send these controls to indicate that the input buffer has enough space for further reception.
So , I've added the corresponding code when flushing input buffer like following.
 *	helper subroutine which checks if XON must be sent
 *  it takes also care of the HW flow control
static rtems_status_code InputFlowCheckResume (struct rtems_termios_tty *tty)
/* if tx stopped and XON should be sent... */
	if (((tty->flow_ctrl & (FL_MDXON | FL_ISNTXOF))
    	==                (FL_MDXON | FL_ISNTXOF))
		&& ((tty->rawOutBufState == rob_idle)
		|| (tty->flow_ctrl & FL_OSTOP))) {
    	/* XON should be sent now... */
    	(*tty->device.write)(tty->minor, &(tty->termios.c_cc[VSTART]), 1);
	else if (tty->flow_ctrl & FL_MDRTS) {
    	tty->flow_ctrl &= ~FL_IRTSOFF;
    	/* activate RTS line */
	    if (tty->device.startRemoteTx != NULL) {
	      tty->device.startRemoteTx(tty->minor);
 	return RTEMS_SUCCESSFUL;
} // InputFlowCheckResume()
rtems_status_code rtems_termios_ioctl (void *arg){
case TCFLSH:
		switch (args->buffer) {
			case TCIFLUSH:	/* flush input buffer */
				if ( tty->rawInBuf.Tail != tty->rawInBuf.Head ) {/* buffer is not empty*/
					rtems_interrupt_disable (level);
					tty->rawInBuf.Head = tty->rawInBuf.Tail;
					rtems_interrupt_enable (level);
					sc = InputFlowCheckResume(tty);
				break;
			case TCOFLUSH:	/* flush output buffer*/
				if ( tty->rawOutBuf.Tail != tty->rawOutBuf.Head ) {/* buffer is not empty*/
					tty->rawOutBuf.Head = tty->rawOutBuf.Tail;
				break;
			case TCIOFLUSH:	/* flush input & output buffer*/
				if ( tty->rawInBuf.Tail != tty->rawInBuf.Head ){
				break;
Kind regards.
Stéphane.
> -----Message d'origine-----
> De : Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
> Envoyé : mercredi 2 mai 2007 22:30
> À : Joel Sherrill
> Cc : Eric Norum; rtems-users at rtems.org; Arquer Stephane
> Objet : Re: RE : Rtems_termios_ioctl problem
> Joel,
> Joel Sherrill schrieb:
> > Thomas Doerfler wrote:
> Should this code be moved to a helper subroutine that is
> invoked from both places?
> Yes Joel, this would be nice, especially since it only
> requires "tty" as an argument. The name of this function
> could be "inputFlowCheckResume" or something like this...
> Stephane, can you try to implement this?
> wkr,
> Thomas.
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at:
>      http://www.imd-systems.de/pgpkey_en.html
