malloc problem
Till Straumann
strauman at slac.stanford.edu
Fri May 11 17:21:21 UTC 2007
Samuel Bitton wrote:
> Sorry forgot to mention, I'm using RTEMS 4.6.6.
> Also note that I've tried calloc which gives me the same problem.
Your application isn't calling malloc/calloc from an ISR
or a code section with thread dispatching disabled, is it?
T.
> *From:* rtems-users-bounces+s.bitton=sstl.co.uk at rtems.org
> [mailto:rtems-users-bounces+s.bitton=sstl.co.uk at rtems.org] *On Behalf
> Of *Samuel Bitton
> *Sent:* 11 May 2007 10:27
> *To:* RTEMS Users Mailing List
> *Subject:* malloc problem
> I am working on an application running on 386 with custom built BSP.
> Calls to malloc in my application keep returning a null value.
> malloc_free_space reports a free heap of 3.9M (as I would expect for
> my configuration).
> I've tried multiple calls to malloc interleaved with a check of the
> free heap and it indicates that the free heap goes down correctly in
> line with the memory I try to malloc but malloc always returns null.
> Is that a known bug with malloc? Or am I missing something somewhere?
> Thanks for your helps
> Sam
> This e-mail and any attachments may contain confidential and
> privileged information. If you are not the intended recipient,
> please notify the sender immediately by return e-mail, delete this
> e-mail and destroy any copies. Any dissemination or use of this
> information by a person other than the intended recipient is
> unauthorised and may be illegal.
> Surrey Satellite Technology Limited
> Registered Office: Senate House, University of Surrey, Guildford,
> Surrey, GU2 7XH Registered in England & Wales No. 1916260 . VAT
> Registration No. GB 413 5711 79
> rtems-users mailing list
> rtems-users at rtems.com
