sem_timedwait error
Tue May 15 15:52:55 UTC 2007
Aitor.Viana.Sanchez at esa.int wrote:
> Hi,
> i am working with rtems 4.6 over LEON2 architecture. I got a problem
> with the sem_timedwait POSIX function. This function has the next
> declaration:
> int sem_timedwait(sem_t *restrict /sem/, const struct timespec
> *restrict /abs_timeout/);
> the problem is that the abs_timeout must have the field tv_nsec
> cleared (set to 0x0) otherwise the function is not executed correctly.
> I think this is a bug in the POSIX API and I guess it would also
> affect other platforms.
> Moreover, the problem is considerable for real-time systems because of
> the lost of precision.
It looks like a bad edit in the error checking code.  It is the remains
of code that
was trying to see if tv_sec or tv_nsec is < 0.  Try the attached patch.
This was probably introduced as part of fixing PR841.
FWIW the same code is in an "#if 0" block on the 4.7 branch and on the
CVS head,
the error checking is done by a helper routine so it is the same
everywhere.  I
saw this type of code in a lot of places and moved it to a common and
hopefully
more correct routine.
Let me know if this works.
--joel
> Any idea ?
> Cheers,
> Aitor
> rtems-users mailing list
> rtems-users at rtems.com
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20070515/e15fc79b/attachment-0001.bin>
