adding a new driver in RTEMS
Aitor.Viana.Sanchez at esa.int
Wed May 16 14:35:46 UTC 2007
Hi Joel,
i am working with the rtems-4.6.5 version. I performed all the steps you
mentioned before (also the ones for the older versions) and when i try to
compile the RTEMS distribution i get an error:
make[7]: *** No rule to make target
`../../../../../../../leon2/lib/include/bspopts.h', needed by
`preinstall-am'. Stop.
make[7]: Leaving directory
`/home/aitor/gaisler/b-rtems/sparc-rtems/c/leon2/lib/libbsp/sparc/leon2/include'
make[6]: *** [preinstall-recursive] Error 1
make[6]: Leaving directory
`/home/aitor/gaisler/b-rtems/sparc-rtems/c/leon2/lib/libbsp/sparc/leon2'
make[5]: *** [preinstall-recursive] Error 1
make[5]: Leaving directory
`/home/aitor/gaisler/b-rtems/sparc-rtems/c/leon2/lib/libbsp/sparc'
make[4]: *** [preinstall-recursive] Error 1
make[4]: Leaving directory
`/home/aitor/gaisler/b-rtems/sparc-rtems/c/leon2/lib/libbsp'
make[3]: *** [preinstall-recursive] Error 1
make[3]: Leaving directory
`/home/aitor/gaisler/b-rtems/sparc-rtems/c/leon2'
make[2]: *** [erc32] Error 1
make[2]: Leaving directory `/home/aitor/gaisler/b-rtems/sparc-rtems/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/aitor/gaisler/b-rtems/sparc-rtems/c'
make: *** [all-recursive] Error 1
Any idea ?
Cheers,
Aitor
rtems-users-bounces+aitor.viana.sanchez=esa.int at rtems.org wrote on
16/05/2007 15:17:43:
> Aitor.Viana.Sanchez at esa.int wrote:
> > Hi everybody,
> > i want to add a new driver in the RTEMS source code for a leon2
> > platform. The driver directory i created is:
> > *c/src/lib/libbsp/sparc/leon2/mydriver*
> > and I also put the header file in the
> > *c/src/lib/libbsp/sparc/leon2/include/* directory (both directories
> > relative to the src root directory).
> > What do I need to add to the Makefiles (or whereever) to compile my
> > drivers and to include them in the final RTEMS compiled version ?
> Depending on the version of RTEMS the instructions differ in precise
> details but
> in general terms, they are:
> + make sure you have the proper RTEMS automake and autoconf installed
> and at the head of your PATH
> + Add your driver to the libbsp/sparc/leon2/Makefile.am
> + (older RTEMS) Add libbsp/sparc/leon2/mydriver/Makefile.am
> + (older RTEMS) Add mydriver to wrapup/Makefile.am
> + while in libbsp/sparc/leon2 run bootstrap
> In newer RTEMS versions, there is only 1 Makefile.am per BSP (ignoring
> tools)
> and all edits are in there.
> --joel
> > Many thanks
> > Aitor
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20070516/70022cf1/attachment-0001.html>
