RES: Problem when running hello_world_c with RTEMS 4.7.1 for SPARC
Fabrício de Novaes Kucinskis
fabricio at dea.inpe.br
Mon May 21 13:33:04 UTC 2007
>>>> Are you using the erc32 or sis BSP to run on gdb's simulator? The sis
>>>> BSP enables extra initialization not required on the real hardware.
>> I'm using SIS to run it. As far as I know, this is the default target for
>> the ERC32 BSP, so it should run without problem. I'd like to know if the
>> call to __bsp_board_init was removed by mistake; if not, why
hello_world_c
>> doesn't run on SIS?
Oops, my mistake.
I was using the erc32 BSP. In fact, I didn't even know there was a SIS BSP.
I remember to read something about it, but, as there is no "sis" folder
under "/lib/libbsp/sparc", I didn't pay much attention.
I removed the call to __bsp_board_init, built a SIS BSP and run under GDB.
It's everything ok. I'm going to try the ERC32 BSP now (running on a board).
So please, disconsider my previous questions.
Thank you again,
Fabrício.
