gcc compiler bug (sparc, ppc)
Joel Sherrill
joel.sherrill at oarcorp.com
Wed May 23 11:30:02 UTC 2007
Sergei Organov wrote:
> Till Straumann <strauman at slac.stanford.edu> writes:
>> I found that gcc produces bad code for the
>> following example:
>> struct node {
>> struct node *next, *prev;
>> void xtract(struct node *x)
>> struct node *n, *p;
>> n = x->n;
>> p = x->p;
>> n->prev = p;
>> p->next = n;
> This doesn't compile:
> np.c: In function ‘xtract’:
> np.c:8: error: ‘struct node’ has no member named ‘n’
> np.c:9: error: ‘struct node’ has no member named ‘p’
> I think you mean:
> struct node *n, *p;
> n = x->next;
> p = x->prev;
> n->prev = p;
> p->next = n;
> right?
Changing the structure definition to make the pointers volatile appears
to result in correct code.
>> powerpc-rtems-gcc -O -fschedule-insns -fno-strict-aliasing
>> (version 4.1.1) produces:
>> The order of the last two assignments was swapped
>> which makes a difference in the special case where &p->next and
>> &n->prev are addressing the same location but n != p.
> You mean when *n and *p overlap like this?:
> n -> |next|prev|
> p -> |next|prev|
>> The bug is apparently triggered by -fschedule-insns; if I turn
>> on all other optimizations (including -fstrict-aliasing) correct
>> code is generated.
> -fstrict-aliasing should have no effect here, I think, as all the
> pointers involved have the same type and are therefore allowed to alias
> each other anyway.
> PPC GCC 2.95.2 seems to produce correct code using
> powerpc-rtems-gcc -O -fschedule-insns -fno-strict-aliasing:
> xtract:
> lwz %r11,0(%r3) # r11 = n = x->next
> lwz %r9,4(%r3) # r9 = p = x->prev
> stw %r9,4(%r11) # n->prev = p
> stw %r11,0(%r9) # p->next = n
> blr
> Overall, it looks like gcc bug indeed. Did you file bug-report?
> -- Sergei.
> rtems-users mailing list
> rtems-users at rtems.com
