Pc386 bsp problem
Arquer Stephane
stephane.arquer at stage.cnes.fr
Wed May 23 15:14:18 UTC 2007
Hi,
Most of time I don't have any execption number, the task is cancelled while the other are continuing to work and sometimes there is an exception raised but I can't catch it because the console displays lines in continuous. It is the same with remote gdb, I can't see the problem with gdb in remote mode, there is no message.
This problem occurs when I use complex simulnk models. I think it is a memory configuration allowed for a task. I use floating point unit and I need to do some calculations.
The task which call the step function is created as follow:
mode = RTEMS_PREEMPT + RTEMS_TIMESLICE + RTEMS_INTERRUPT_LEVEL(0);
attributs = RTEMS_FLOATING_POINT + RTEMS_LOCAL ;
status = rtems_task_create(nommage("simuLoi"),
current_priority,
RTEMS_MINIMUM_STACK_SIZE,
mode,
attributs,
&id_tLoi);
And my configuration is :
configuration information
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
#define CONFIGURE_TEST_NEEDS_TIMER_DRIVER
#define CONFIGURE_INIT_TASK_PRIORITY 110
#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT + RTEMS_LOCAL
#define CONFIGURE_MAXIMUM_TASKS 128
#define CONFIGURE_MAXIMUM_SEMAPHORES 20
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 10
#define CONFIGURE_MAXIMUM_TIMERS 16
#define CONFIGURE_MAXIMUM_PERIODS 16
#define CONFIGURE_MICROSECONDS_PER_TICK 1000 // 1 tick every 1ms
#define CONFIGURE_TICKS_PER_TIMESLICE 200
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#ifdef pc386
#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
rtems_driver_address_table Device_drivers[5] = {
CONSOLE_DRIVER_TABLE_ENTRY,
TTY1_DRIVER_TABLE_ENTRY,
TTY2_DRIVER_TABLE_ENTRY,
CLOCK_DRIVER_TABLE_ENTRY,
{NULL, NULL, NULL, NULL, NULL, NULL}
#endif //pc386
#define CONFIGURE_EXTRA_TASK_STACKS (3 * RTEMS_MINIMUM_STACK_SIZE)
#define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 10
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
#include <confdefs.h>
Thanks for your help.
Stephane.
> -----Message d'origine-----
> De : Daron Chabot [mailto:daron.chabot at usask.ca]
> Envoyé : mardi 15 mai 2007 17:35
> À : Arquer Stephane
> Cc : rtems-users at rtems.org
> Objet : Re: RE : Pc386 bsp problem
> On Mon, 2007-05-14 at 17:34 +0200, Arquer Stephane wrote:
> > The failure is an execption raised bay the "simuLoi" task when it
> > calls the step function. The task is canceled by the
> scheduler, only
> > "trwsr" and "trwsw" are running for a moment then a complete crash
> > occurs. When I compile the same code with the leon3 bsp, tsim
> > simulator works fine.
> Exactly what information does the exception provide ?
> (exception number,
> etc.)
> Can you use a debugger (gdb) to step through
> "task_gestion_loi( )" and see precisely where the exception
> is being raised ?
> -- dc
