Pc386 bsp problem
Joel Sherrill
joel.sherrill at oarcorp.com
Thu May 24 14:17:15 UTC 2007
Arquer Stephane wrote:
> I redefined
> #define CONFIGURE_INIT_TASK_STACK_SIZE (512*1024)
That's a lot of memory. Does it even get to the Init task?
> It doesn't do anything.
> Can you tell me how to connect the console to com1 ?
> I tried to use :
> #define USE_COM1_AS_CONSOLE 1
> But it doesn't work.
> I believe that the raise exception is 6 but I'm not sure. With the terminal I'll catch the error code.
AFAIK this is a configure time option to the BSP.
.../configure USE_COM1_AS_CONSOLE=1 --target....
Someone should correct me if I got that wrong.
--joel
> Thanks.
> Stéphane.
>> -----Message d'origine-----
>> De : Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>> Envoyé : jeudi 24 mai 2007 15:21
>> À : Arquer Stephane
>> Cc : Daron Chabot; rtems-users at rtems.org
>> Objet : Re: RE : RE : RE : Pc386 bsp problem
>>> Good morning,
>>> I changed the stack configuration to:
>>> #define CONFIGURE_EXTRA_TASK_STACKS (64*1024)
>> That only reserves 64k more memory for task stacks. It
>> doesn't result in any task getting more stack.
>> You need to increase the stack size on any task create
>> operations and define CONFIGURE_INIT_TASK_STACK_SIZE to
>> something other than the default below from confdefs.h.
>> #define CONFIGURE_INIT_TASK_STACK_SIZE RTEMS_MINIMUM_STACK_SIZE
>>> The problem is the same, the task is deleted.
>> If your task is calling the simulink generated code and that
>> code returns, your hand written task must be able to account for that.
>> call simulink code
>> ??? do something if it returns ???
>> If you fall out the bottom of the task, it is a fatal error. }
>>>> Envoyé : mercredi 23 mai 2007 17:22
>>>> À : Arquer Stephane
>>>> Objet : Re: RE : RE : Pc386 bsp problem
>>>>> Hi,
>>>>> Most of time I don't have any execption number, the task is
>>>> cancelled
>>>>> while the other are continuing to work and sometimes there is an
>>>>> exception raised but I can't catch it because the console
>> displays
>>>>> lines in continuous. It is the same with remote gdb, I
>>>> can't see the
>>>>> problem with gdb in remote mode, there is no message.
>>>>> This problem occurs when I use complex simulnk models. I
>>>> think it is a
>>>>> memory configuration allowed for a task. I use floating
>>>> point unit and
>>>>> I need to do some calculations. The task which call the
>>>> step function
>>>>> is created as follow:
>>>>> mode = RTEMS_PREEMPT + RTEMS_TIMESLICE + RTEMS_INTERRUPT_LEVEL(0);
>>>>> attributs = RTEMS_FLOATING_POINT + RTEMS_LOCAL ;
>>>>> status = rtems_task_create(nommage("simuLoi"),
>>>>> current_priority,
>>>>> RTEMS_MINIMUM_STACK_SIZE,
>>>>> mode,
>>>>> attributs,
>>>>> &id_tLoi);
>>>> You can try making the stack large like 64K and adding that to your
>>>> confdefs.h
>>>> (EXTRA_STACKS). If this is generated code, it can be very
>>>> abusive on the stack.
>>>> You could also switch the console to COM1 and using a
>>>> terminal program to talk to the target. That way you would
>>>> have logs of the output.
>>> I've tried to use :
>>>>> And my configuration is :
>>>> configuration information
>>>>> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
>>>>> #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
>>>>> #define CONFIGURE_TEST_NEEDS_TIMER_DRIVER
>>>>> #define CONFIGURE_INIT_TASK_PRIORITY 110
>>>>> #define CONFIGURE_INIT_TASK_ATTRIBUTES
>>>>> #define CONFIGURE_MAXIMUM_TASKS 128
>>>>> #define CONFIGURE_MAXIMUM_SEMAPHORES 20
>>>>> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 10
>>>>> #define CONFIGURE_MAXIMUM_TIMERS 16
>>>>> #define CONFIGURE_MAXIMUM_PERIODS 16
>>>>> #define CONFIGURE_MICROSECONDS_PER_TICK
>>>> 1000 // 1 tick every 1ms
>>>>> #define CONFIGURE_TICKS_PER_TIMESLICE 200
>>>>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>>> #ifdef pc386
>>>>> #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
>>>>> rtems_driver_address_table Device_drivers[5] = {
>>>>> CONSOLE_DRIVER_TABLE_ENTRY,
>>>>> TTY1_DRIVER_TABLE_ENTRY,
>>>>> TTY2_DRIVER_TABLE_ENTRY,
>>>>> CLOCK_DRIVER_TABLE_ENTRY,
>>>>> {NULL, NULL, NULL, NULL, NULL, NULL}
>>>>> #endif //pc386
>>>>> #define CONFIGURE_EXTRA_TASK_STACKS (3 *
>>>> RTEMS_MINIMUM_STACK_SIZE)
>>>>> #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 10
>>>>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
>>>>> #include <confdefs.h>
>>>>> Thanks for your help.
>>>>> Stephane.
>>>>>> De : Daron Chabot [mailto:daron.chabot at usask.ca]
>>>>>> Envoyé : mardi 15 mai 2007 17:35
>>>>>> À : Arquer Stephane
>>>>>> Cc : rtems-users at rtems.org
>>>>>> Objet : Re: RE : Pc386 bsp problem
>>>>>> On Mon, 2007-05-14 at 17:34 +0200, Arquer Stephane wrote:
>>>>>>> The failure is an execption raised bay the "simuLoi"
>> task when it
>>>>>>> calls the step function. The task is canceled by the
>>>>>> scheduler, only
>>>>>>> "trwsr" and "trwsw" are running for a moment then a
>> complete crash
>>>>>>> occurs. When I compile the same code with the leon3 bsp, tsim
>>>>>>> simulator works fine.
>>>>>> Exactly what information does the exception provide ? (exception
>>>>>> number,
>>>>>> etc.)
>>>>>> Can you use a debugger (gdb) to step through
>> "task_gestion_loi( )"
>>>>>> and see precisely where the exception is being raised ?
>>>>>> -- dc
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.com
>>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
