Pc386 bsp problem
Joel Sherrill
joel.sherrill at oarcorp.com
Thu May 24 15:04:18 UTC 2007
Arquer Stephane wrote:
> Effectively, I changed the creation mode of the task and it's working fine.
> Thanks.
Great!! Could you write up something on using Simulink with RTEMS and
let us add it to the Wiki?
If you get anything you can write up about your project, please add it
to the
Wiki.
--joel
>> -----Message d'origine-----
>> De : Daron Chabot [mailto:djc915 at mail.usask.ca]
>> Envoyé : jeudi 24 mai 2007 16:58
>> À : Arquer Stephane
>> Cc : RTEMS
>> Objet : Re: RE : Pc386 bsp problem
>> On 24-May-07, at 8:13 AM, Arquer Stephane wrote:
>>> I redefined
>>> #define CONFIGURE_INIT_TASK_STACK_SIZE (512*1024)
>>> It doesn't do anything.
>> I believe you must explicitly set your tasks' stack size when you
>> create them. Simply setting CONFIGURE_EXTRA_TASK_STACKS will not
>> accomplish the desired effect. And as Joel has pointed out, it is a
>> fatal error to have a task (thread) return in the RTEMS native API.
>>> Can you tell me how to connect the console to com1 ?
>>> I tried to use :
>>> #define USE_COM1_AS_CONSOLE 1
>>> But it doesn't work.
>> I'll have to check this point...
>>> I believe that the raise exception is 6 but I'm not sure. With the
>>> terminal I'll catch the error code.
>> Exception 6 is an invalid opcode. Perhaps your matlab code is
>> attempting to perform SIMD (MMX) operations, while your
>> platform does
>> not support it ?? Just speculation....
>> What hardware are you running this on ?
>> -- dc
>>> Thanks.
>>> Stéphane.
>>>> De : Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>>>> Envoyé : jeudi 24 mai 2007 15:21
>>>> À : Arquer Stephane
>>>> Cc : Daron Chabot; rtems-users at rtems.org
>>>> Objet : Re: RE : RE : RE : Pc386 bsp problem
>>>>> Good morning,
>>>>> I changed the stack configuration to:
>>>>> #define CONFIGURE_EXTRA_TASK_STACKS (64*1024)
>>>> That only reserves 64k more memory for task stacks. It doesn't
>>>> result in any task getting more stack.
>>>> You need to increase the stack size on any task create
>> operations and
>>>> define CONFIGURE_INIT_TASK_STACK_SIZE to something other than the
>>>> default below from confdefs.h.
>>>> #define CONFIGURE_INIT_TASK_STACK_SIZE RTEMS_MINIMUM_STACK_SIZE
>>>>> The problem is the same, the task is deleted.
>>>> If your task is calling the simulink generated code and that code
>>>> returns, your hand written task must be able to account for
>>>> that.
>>>> call simulink code
>>>> ??? do something if it returns ???
>>>> If you fall out the bottom of the task, it is a fatal error. }
>>>>>> Envoyé : mercredi 23 mai 2007 17:22
>>>>>> À : Arquer Stephane
>>>>>> Objet : Re: RE : RE : Pc386 bsp problem
>>>>>>> Hi,
>>>>>>> Most of time I don't have any execption number, the task is
>>>>>> cancelled
>>>>>>> while the other are continuing to work and sometimes
>> there is an
>>>>>>> exception raised but I can't catch it because the console
>>>> displays
>>>>>>> lines in continuous. It is the same with remote gdb, I
>>>>>> can't see the
>>>>>>> problem with gdb in remote mode, there is no message.
>>>>>>> This problem occurs when I use complex simulnk models. I
>>>>>> think it is a
>>>>>>> memory configuration allowed for a task. I use floating
>>>>>> point unit and
>>>>>>> I need to do some calculations. The task which call the
>>>>>> step function
>>>>>>> is created as follow:
>>>>>>> mode = RTEMS_PREEMPT + RTEMS_TIMESLICE +
>> RTEMS_INTERRUPT_LEVEL(0);
>>>>>>> attributs = RTEMS_FLOATING_POINT + RTEMS_LOCAL ;
>>>>>>> status = rtems_task_create(nommage("simuLoi"),
>>>>>>> current_priority,
>>>>>>> RTEMS_MINIMUM_STACK_SIZE,
>>>>>>> mode,
>>>>>>> attributs,
>>>>>>> &id_tLoi);
>>>>>> You can try making the stack large like 64K and adding
>> that to your
>>>>>> confdefs.h (EXTRA_STACKS). If this is generated code, it can be
>>>>>> very abusive on the stack.
>>>>>> You could also switch the console to COM1 and using a terminal
>>>>>> program to talk to the target. That way you would have
>> logs of the
>>>>>> output.
>>>>> I've tried to use :
>>>>>>> And my configuration is :
>>>>>> configuration information
>>>>>>> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
>>>>>>> #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
>>>>>>> #define CONFIGURE_TEST_NEEDS_TIMER_DRIVER
>>>>>>> #define CONFIGURE_INIT_TASK_PRIORITY 110
>>>>>>> #define CONFIGURE_INIT_TASK_ATTRIBUTES
>>>>>>> #define CONFIGURE_MAXIMUM_TASKS 128
>>>>>>> #define CONFIGURE_MAXIMUM_SEMAPHORES 20
>>>>>>> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
>> 10
>>>>>>> #define CONFIGURE_MAXIMUM_TIMERS
>> 16
>>>>>>> #define CONFIGURE_MAXIMUM_PERIODS
>> 16
>>>>>>> #define CONFIGURE_MICROSECONDS_PER_TICK
>>>>>> 1000 // 1 tick every 1ms
>>>>>>> #define CONFIGURE_TICKS_PER_TIMESLICE 200
>>>>>>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>>>>> #ifdef pc386
>>>>>>> #define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
>>>>>>> rtems_driver_address_table Device_drivers[5] = {
>>>>>>> CONSOLE_DRIVER_TABLE_ENTRY,
>>>>>>> TTY1_DRIVER_TABLE_ENTRY,
>>>>>>> TTY2_DRIVER_TABLE_ENTRY,
>>>>>>> CLOCK_DRIVER_TABLE_ENTRY,
>>>>>>> {NULL, NULL, NULL, NULL, NULL, NULL}
>>>>>>> #endif //pc386
>>>>>>> #define CONFIGURE_EXTRA_TASK_STACKS (3 *
>>>>>> RTEMS_MINIMUM_STACK_SIZE)
>>>>>>> #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS
>> 10
>>>>>>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
>>>>>>> #include <confdefs.h>
>>>>>>> Thanks for your help.
>>>>>>> Stephane.
>>>>>>>> De : Daron Chabot [mailto:daron.chabot at usask.ca]
>>>>>>>> Envoyé : mardi 15 mai 2007 17:35
>>>>>>>> À : Arquer Stephane
>>>>>>>> Cc : rtems-users at rtems.org
>>>>>>>> On Mon, 2007-05-14 at 17:34 +0200, Arquer Stephane wrote:
>>>>>>>>> The failure is an execption raised bay the "simuLoi"
>>>> task when it
>>>>>>>>> calls the step function. The task is canceled by the
>>>>>>>> scheduler, only
>>>>>>>>> "trwsr" and "trwsw" are running for a moment then a
>>>> complete crash
>>>>>>>>> occurs. When I compile the same code with the leon3 bsp, tsim
>>>>>>>>> simulator works fine.
>>>>>>>> Exactly what information does the exception provide ?
>> (exception
>>>>>>>> number,
>>>>>>>> etc.)
>>>>>>>> Can you use a debugger (gdb) to step through
>>>> "task_gestion_loi( )"
>>>>>>>> and see precisely where the exception is being raised ?
>>>>>>>> -- dc
>>>>>>> _______________________________________________
>>>>>>> rtems-users mailing list
>>>>>>> rtems-users at rtems.com
>>>>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
