gcc compiler -O flags (was Re: gcc compiler bug)
Ralf Corsepius ralf.corsepius at rtems.org
Fri May 25 16:06:16 UTC 2007
On Fri, 2007-05-25 at 11:26 -0400, Kate Feng wrote:
> For this particular  case that Till mentioned,  the result is inversed
> between -O,  and -O2 (-O4,  too).
Does this affect any code in RTEMS or is this an accademical example?
In any case, did any of you report this to gcc@?
Ralf
