Problem when installing 4.8 using yum.
Ralf Corsepius
ralf.corsepius at rtems.org
Tue May 29 13:38:28 UTC 2007
On Tue, 2007-05-29 at 16:37 +0400, Sergei Organov wrote:
> Hello,
> I'm trying to install RTEMS tools using yum (3.0.3) on FC6.
> # yum -c /etc/yum/yum.rtems.com install rtems-4.8-automake-rtems
> Downloading Packages:
> (1/2): rtems-4.8-autoconf 100% |=========================| 623 kB 00:03
> (2/2): rtems-4.8-automake 100% |=========================| 598 kB 00:03
> warning: rpmts_HdrFromFdno: Header V3 DSA signature: NOKEY, key ID 69ce4a83
> Public key for rtems-4.8-autoconf-2.61-5.noarch.rpm is not installed
> How do I fix this?
Normally, a properly configured yum set up asks you to install the
key ...
... but ... I see, you seem to be using a self-written one ;)
If you want to continue to use your own config, you'll have to install
the gpg key manually:
rpm --import \
ftp://ftp.rtems.org/pub/rtems/linux/gpg-pubkey-69ce4a83-44cc2b30
Alternatively (and that what I recommend), you could use our official
yum configuration:
rpm -U ftp://ftp.rtems.org/pub/rtems/linux/4.8/fedora/6/i386/rtems-4.8-yum-conf-0.7-1.fc6.noarch.rpm
yum install <.....>
> [Disclaimer: I usually use Debian-based systems, so have almost no clue
> on how yum works]
Then use apt ;) It's supported by Fedora 6 as well. We provide a
configuration package as well:
rpm -U \
ftp://ftp.rtems.org/pub/rtems/linux/4.8/fedora/6/i386/rtems-4.8-apt-conf-0.7-1.fc6.noarch.rpm
apt-get update
apt-get install <....>
Ralf
