skyeye/edb7312 help request
Joel Sherrill
joel.sherrill at oarcorp.com
Wed May 30 00:59:47 UTC 2007
OK. I don't know what the problem was but the skyeye.conf I had
carefully safed did not begin to match the memory map of the
edp7312 although it picked the right cpu type. The more correct
configuration file is:
cpu: arm720t
mach: ep7312
mem_bank: map=I,type=RW, addr=0x80000000, size=0x00100000
mem_bank: map=M, type=RW, addr=0x00000000, size=0x1000000
log: logon=1, logfile=/tmp/sk1.log, start=2000000, end=3000000
I am not sure the memory map is dead on but I am sure we don't want
the log on but it is late here and I should be home.
By any chance does someone know how to make this simulator trap
to an exit?
Or why it stops when it is run in the background?
--joel
Joel Sherrill wrote:
> Hi,
> Does anyone have the edp7312
> running on skyeye anymore?
> I don't seem to be able to make it
> happen with my old skyeye source. :(
> --joel
> rtems-users mailing list
> rtems-users at rtems.com
