how does newlib work with rtmes?
Ralf Corsepius ralf.corsepius at rtems.org
Thu Nov 1 09:03:36 UTC 2007
On Wed, 2007-10-31 at 20:00 +0800, Ray wrote:
> It is better to use the newlib(newlib-1.15.0) original version.
Wrong. Vanilla newlib is non-compatible to RTEMS.
> Because it will made it hard to maintain a separate newlibc for MSP.
You should submit your changes upstream to newlib and GCC instead.
That's how opensource works.
>  Newlibc full bundle will not add much overhead to the systems because
> RTEMS only link in the lib/func needed for your app.
Right.
> BTW, RTEMS can run without libc for minium.exe if you do not
>  include fs.
Well, yes, RTEMS can run a useless function-free application without
newlib. For real world applications you won't get far without newlib.
newlib is an essential and deeply integrated component of RTEMS.
Ralf
