RTEMS autotools installation on mingw
Sven.BIEBAUT at be.thalesgroup.com Sven.BIEBAUT at be.thalesgroup.com
Tue Nov 6 08:15:40 UTC 2007
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: 05 November, 2007 21:20
> To: Sven.BIEBAUT at be.thalesgroup.com
> Cc: rtems-users at rtems.org
> Subject: Re: RTEMS autotools installation on mingw
> Sven.BIEBAUT at be.thalesgroup.com wrote:
> > Hello,
> > as a new user to rtems, i tried to install the mingw based
> windows tools (i
> > want to combine it with other windows based
> > development tools).
> > I installed mingw, msys and msysDTK and proceeded as per
> the wiki page with
> > the RTEMS tools installer(rtems4.8-tools-16.exe). As this
> development pc is
> > not internet connected, I downloaded the packages first on
> a memory stick
> > and installed them from there.
> Where did you install them to?
I installed mingw to c:\mingw and msys (and its dtk)  to c:\mingw\msys.
I added (manually) c:\mingw\bin and c:\mingw\msys\bin to my path variable. Both work equally fine: the unix commands (ls, make, .. ) work well at the command prompt. This does not change the error though, with or without it stays the same.
> Do you have a Msys icon on your desktop?  Does it work?
The icon of msys on my desktop i created myself, but it does work. I get a functional unix shell.
> > The RTEMS installer however complains about "Cannot open
> > not-found/etc/fstab. MSYS mount point not added".
> Apparently this seems only
> > to affect the autotools sub package. I tried setting the
> HOME environment
> > variable, but this does not change alot.
> It looks like you didn't really install mingw and msys.  That's what
> the message means.
Problem is that the host is not internet connected, so i cannot use the minw installer directly as it will fetch packages from internet. In stead, I used two alternatives, first a copy of the whole tree of an install on an internet connected pc ( should work from what i read on the mingw wiki) and a manual install, which is basically extracting all the necessary packages from sourceforge. Both yield the same error.
> > If I continue and disregard the message it will proceed
> with the actual
> > compiler installation, but in the end complain that it
> couldn't find mingw.
The first error about the MSYS mountpoint is right at startup of the installer and the second (about mingw) is at the end of the installing process.
> > Is there something that I missed ? Do I need administrator
> rights or are
> > there other environment variables necessary?
> > Thanks in advance,
> > Sven Biebaut
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
