Porting RTEMS on TriMedia
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Tue Nov 6 09:05:52 UTC 2007
Hi,
Jalpan Dholakia schrieb:
> Hello,
> I several questions on RTEMS which I was not able to get from RTEMS wiki.
> Has any body ported RTEMS on TriMedia?
> It is written in the wiki that RTEMS has not been tried to compile with
> non GNU compiler. But what it means whether is it possible to use non
> GNU compiler ?
The RTEMS source code relies on a few very specific constructs of the
GNU C Compiler, e.g. to avoid problems due to over-optimization. RTEMS
also is tightly bound to "newlib" as a C standard library. So there are
some areas to adapt when a different compiler is to be used with RTEMS.
Another issue is, that the RTEMS community works based on open source
compilers, so it would be very difficult to maintain code for a
processor that is not supported by GCC.
wkr,
Thomas Dörfler.
> Regards,
> Jalpan Dholakia
> Philips-NXP Semiconductors
> Corporate Innovation & Technology / Intellectual Property & Architecture
> E-mail: jalpan.dholakia at nxp.com
> (OR jalpan.dholakia at philips.com)
> High Tech Campus 46 - Room 3.56
> 5656 AE Eindhoven, The Netherlands
> Tel: +31 40 2745724
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
