Unable to load examples for RTEMS for GBA
Thu Nov 8 20:54:31 UTC 2007
Micronian wrote:
> Hi,
> I just built RTEMS 4.8 and GCC 4.2.2 using target=arm-rtems and
> selected the gba BSP. I read somewhere on the mailing list that it is
> possible to load the EXE files (under testsuites) in a emulator. I
> downloaded VisualBoyAdvance but when I try to load one of the EXEs
> (e.g. hello.exe) it says "Unknown file type". I don't have a real GBA
> to play with, so that is why I need an emulator.
I'm on Linux and tried ticker.exe built from the CVS head.
It ran using a GBA simulator named BoyCott Advance
that I downloaded a while back.
I have only found a MS-Windows VisualBoyAdvance version.
If you have a GNU/Linux one, I would like to know.
> Can anyone shed some light? This is my first time exploring RTEMS.
> Thanks!
> rtems-users mailing list
> rtems-users at rtems.com
